I have got a Notebook with a dual gpu setup. I only use the display from the laptop itself, it supports 165hz. I turned on 165hz and it still runs with 60hz despite xrandr saying it runs with 165.
glxgears with vsync runs with 60hz, as well as testufo. On windows it feels 10x smoother because it really uses 165hz. Does anybody have any idea what could cause this?
Below you find various outputs of xrandr, mhwd and inxi:
Screen 0: minimum 320 x 200, current 2560 x 1600, maximum 16384 x 16384
eDP-1 connected primary 2560x1600+0+0 (normal left inverted right x axis y axis) 344mm x 215mm
2560x1600 165.00*+ 60.00 + 59.99 59.97
2560x1440 59.99 59.99 59.96 59.95
2048x1536 85.00 75.00 60.00
1920x1440 85.00 75.00 60.00
1856x1392 75.00 60.01
1792x1344 75.00 60.01
2048x1152 59.99 59.98 59.90 59.91
1920x1200 59.88 59.95
1920x1080 60.01 59.97 59.96 59.93
1600x1200 85.00 75.00 70.00 65.00 60.00
1680x1050 59.95 59.88
1400x1050 74.76 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 85.02 75.02 60.02
1400x900 59.96 59.88
1280x960 85.00 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1152x864 75.00
1280x720 60.00 59.99 59.86 59.74
1024x768 85.00 75.05 60.04 85.00 75.03 70.07 60.00
1024x768i 86.96
960x720 85.00 75.00 60.00
928x696 75.00 60.05
896x672 75.05 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
832x624 74.55
960x540 59.96 59.99 59.63 59.82
800x600 85.00 75.00 70.00 65.00 60.00 85.14 72.19 75.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 74.76 59.98
800x450 59.95 59.82
640x512 85.02 75.02 60.02
700x450 59.96 59.88
640x480 85.09 60.00 85.01 72.81 75.00 59.94
720x405 59.51 58.99
720x400 85.04
684x384 59.88 59.85
640x400 59.88 59.98 85.08
576x432 75.00
640x360 59.86 59.83 59.84 59.32
640x350 85.08
512x384 85.00 75.03 70.07 60.00
512x384i 87.06
512x288 60.00 59.92
416x312 74.66
480x270 59.63 59.82
400x300 85.27 72.19 75.12 60.32 56.34
432x243 59.92 59.57
320x240 85.18 72.81 75.00 60.05
360x202 59.51 59.13
360x200 85.04
320x200 85.27
320x180 59.84 59.32
320x175 85.27
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
HDMI-1-0 disconnected (normal left inverted right x axis y axis)
DP-1-0 disconnected (normal left inverted right x axis y axis)
0000:01:00.0 (0300:10de:24dc) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2021.12.18 false PCI
video-hybrid-intel-nvidia-470xx-prime 2021.12.18 false PCI
video-nvidia 2021.12.18 false PCI
video-nvidia-470xx 2021.12.18 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:00:02.0 (0300:8086:9a60) Display controller Intel Corporation:
> Installed PCI configs:
Kernel: 5.15.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=9ff61487-7f53-43b0-a573-c5eef2a78201 rw rootflags=subvol=@ quiet
cryptdevice=UUID=6819d294-1e36-4cd2-bb09-7c8e4d9d4e81:luks-6819d294-1e36-4cd2-bb09-7c8e4d9d4e81
root=/dev/mapper/luks-6819d294-1e36-4cd2-bb09-7c8e4d9d4e81 splash
apparmor=1 security=apparmor
resume=/dev/mapper/luks-0d62a11d-7c8e-4caf-b5be-d0fd0c12166f
udev.log_priority=3
Desktop: GNOME v: 42.1 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: Acer product: Predator PT516-51s v: V1.05
serial: <filter>
Mobo: TGL model: Countryman_TLS v: V1.05 serial: <filter> UEFI: Insyde
v: 1.05 date: 08/03/2021
ID-1: BAT1 charge: 97.3 Wh (100.0%) condition: 97.3/100.0 Wh (97.3%)
volts: 17.2 min: 15.2 model: Getac AP20BHU type: Li-ion serial: <filter>
status: full cycles: 13
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
Info: model: 11th Gen Intel Core i7-11800H socket: U3E1 bits: 64
type: MT MCP arch: Tiger Lake family: 6 model-id: 0x8D (141) stepping: 1
microcode: 0x3C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB desc: 8x1.2 MiB
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1810 high: 3963 min/max: 800/4600 base/boost: 2277/5000
scaling: driver: intel_pstate governor: powersave volts: 0.7 V
ext-clock: 100 MHz cores: 1: 800 2: 1583 3: 3534 4: 802 5: 1858 6: 1932
7: 3963 8: 801 9: 801 10: 800 11: 2815 12: 801 13: 1842 14: 3204 15: 2627
16: 802 bogomips: 73744
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Acer Incorporated ALI
driver: i915 v: kernel ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4
bus-ID: 00:02.0 chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB]
vendor: Acer Incorporated ALI driver: nvidia v: 510.68.02
alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Ampere pcie: gen: 4 speed: 16 GT/s
lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:24dc
class-ID: 0300
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 3-5:4
chip-ID: 0408:a094 class-ID: 0e02
Display: server: X.Org v: 21.1.3 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa gpu: i915 display-ID: :1 screens: 1
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
s-diag: 798mm (31.43")
Monitor-1: eDP-1 model: BOE Display 0x0990 built: 2020 res: 2560x1600
hz: 165 dpi: 189 gamma: 1.2 size: 344x215mm (13.54x8.46") diag: 406mm (16")
ratio: 16:10 modes: 2560x1600
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 22.0.3
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8
class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-3: GYROCOM C&C Fiio E10 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-2:3 chip-ID: 1852:7022
class-ID: 0102
Sound Server-1: ALSA v: k5.15.38-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Realtek Killer E3000 2.5GbE vendor: Acer Incorporated ALI
driver: r8169 v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 4000
bus-ID: 57:00.0 chip-ID: 10ec:3000 class-ID: 0200
IF: enp87s0 state: down mac: <filter>
IF-ID-1: enp0s20f0u1c4i2 state: up speed: N/A duplex: N/A mac: <filter>
bus-ID: 3-14:6 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 953.87 GiB used: 315.23 GiB (33.0%)
model: MZVL21T0HCLR-00B07 size: 953.87 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: GXA7302Q temp: 40.9 C scheme: GPT
SMART: yes health: PASSED on: 69 hrs cycles: 128
read-units: 6,981,646 [3.57 TB] written-units: 18,558,419 [9.50 TB]
ID-1: / raw-size: 742.73 GiB size: 742.73 GiB (100.00%)
used: 315.21 GiB (42.4%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-6819d294-1e36-4cd2-bb09-7c8e4d9d4e81
ID-2: /boot/efi raw-size: 300 MiB size: 296 MiB (98.67%)
used: 13.3 MiB (4.5%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 742.73 GiB size: 742.73 GiB (100.00%)
ID-4: /var/log raw-size: 742.73 GiB size: 742.73 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.6 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-0d62a11d-7c8e-4caf-b5be-d0fd0c12166f
System Temperatures: cpu: 43.0 C mobo: N/A
Processes: 433 Uptime: 14m wakeups: 5 Memory: 15.41 GiB
used: 3.82 GiB (24.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1497 lib: 341 flatpak: 0
Shell: Bash (su) v: 5.1.16 running-in: gnome-terminal inxi: 3.3.16
