Author Topic: PlayOnLinux - "iCCP:known incorrect sRGB profile"?  (Read 9239 times)
Offline mipsTopic starter
  • Held Mitglied
  • Valkyrja
  • Kernel: 3.16
  • Desktop: XFCE
  • Branch: Testing
  • GPU Card: GTX 960
  • GPU driver: video-nvidia
  • Skill: Intermediate
« on: 30. August 2013, 19:34:01 »
I get this error a lot, "iCCP:known incorrect sRGB profile"
How do I fix it, I tried folling a link to the POL site from a google search but the site is currently down.
I installed wine and pol from the repos on my 64-bit openbox syste. I configured wine for a 32-bit environment as per the arch wiki.
Any ideas?
Offline Zediker
  • Neuling
  • Kernel: 3.10.x
  • Desktop: Xfce
  • Branch: stable
  • GPU Card: nvidia 660Ti / nvidia Optimus 540M
  • GPU driver: 325.x / Bumblebee
Re: PlayOnLinux - "iCCP:known incorrect sRGB profile"?
« Reply #1 on: 30. August 2013, 21:33:01 »
I remember an old link saying it had something to do with PNG library libpng 1.6x here: http://www.playonlinux.com/en/topic-10442-New_Warning_Message_on_startup.html
I think there is a manual workaround to correct the faulty PNG icons in POL.
Offline bersil
  • Vollwertiges Mitglied
  • Kernel: Linux 3.14... x86_64
  • Desktop: KDE
  • Branch: stable
  • GPU Card: NVIDIA Corporation C51 [GeForce 6150 LE] (rev a2)
  • GPU driver: nVidia-legacy - non-free driver
« Reply #2 on: 31. August 2013, 12:06:55 »
Hi mips:
the bug is originating from ImageMagick and not POL.
To fix this error try this:
Code: [Select]
su Enter your root password
Code: [Select]
cd /usr/share/playonlinux
Code: [Select]
for i in `find . | grep .png`; do convert "$i" -strip "$i"; done
  • Held Mitglied
  • Valkyrja
  • Kernel: 3.16
  • Desktop: XFCE
  • Branch: Testing
  • GPU Card: GTX 960
« Reply #3 on: 31. August 2013, 13:19:53 »
Thx but that did not work, still getting the annoying popup error message.
Offline bersil
  • Desktop: KDE
  • Branch: stable
« Reply #4 on: 31. August 2013, 14:03:09 »
is a pity,, I solved that.
You have some package libpng installed from AUR? because maybe there is a conflict with the official libpng packages
  • Held Mitglied
  • Valkyrja
  • Kernel: 3.16
  • Desktop: XFCE
  • Branch: Testing
  • GPU Card: GTX 960
« Reply #5 on: 31. August 2013, 15:29:16 »
Nothing from AUR. Only have libpng 1.6.3-1 from extra and lib32-libpng 1.6.3-1 from multilib installed.
Offline bersil
  • Desktop: KDE
  • Branch: stable
« Reply #6 on: 31. August 2013, 16:23:51 »
Well, ok... make one last attempt
maybe the previous command has not cleaned RGB profiles of all pictures
open the terminal  in your Home folder and try this:
(copy & paste into the terminal and then click enter)
Code: [Select]
for i in `pacman -Qql playonlinux`
do
done
It's the last thing that comes to mind
Offline bersil
  • Desktop: KDE
  • Branch: stable
« Reply #7 on: 31. August 2013, 16:39:14 »
sorry, I forgot to tell you that you have to run as root
first
Code: [Select]
suyour root password
an then copy & paste into the terminal
Code: [Select]
do
done
  • Held Mitglied
  • Valkyrja
  • Kernel: 3.16
  • Desktop: XFCE
  • Branch: Testing
  • GPU Card: GTX 960
« Reply #8 on: 03. September 2013, 12:45:19 »
Thanks but still no go.
Offline thundersqueak
  • Held Mitglied
  • everyone dies
  • Kernel: most,if not all
  • Desktop: gnome
  • Branch: all of em
  • GPU Card: nvidia 9300
  • GPU driver: non-free
  • Skill: Novice
« Reply #9 on: 06. September 2013, 11:07:06 »
@mips
went looking for an answer pol release notes state this is a FEATURE of the new libpng lol,i guess you gotta wait for a new pol release with proper icons,doesn't look like they will release a patch  :'(
"Why is it that every grubby little government i pass has the impertinence to assume that i can spare the time and energy necessary for their destruction?"
Offline Ayceman
  • Core Team
  • Security Chief :P
  • Kernel: latest stable+lts (64)
  • Desktop: Xfce
  • Branch: stable, unstable
  • GPU Card: GTX780/HD3000/AMD8400
  • GPU driver: Nvidia/Intel/Catalyst
  • Skill: Advanced
« Reply #10 on: 07. September 2013, 16:18:14 »
Use this:
https://dl.dropboxusercontent.com/u/56330401/playonlinux_images.tar.bz2
And extract it to /usr/share/playonlinux/
EDIT: This:
/usr/share/playonlinux/etc/onglet/wine.png
...might also have and incorrect profile, so you can do:
Code: [Select]
sudo convert /usr/share/playonlinux/etc/onglet/wine.png -strip /usr/share/playonlinux/etc/onglet/wine.png
« Last Edit: 07. September 2013, 16:23:24 by Ayceman »
Offline xtenshisanx
  • Neuling
« Reply #11 on: 10. September 2013, 16:39:50 »
dont know if you still need some help.
Im not using manjaro cuz Im on Archlinux, but Ive done that error with executing this code in the Playonlinux folder (At arch "/usr/share/playonlinux")
Code: [Select]
for i in `find $PWD -name *.png`;do convert "$i" -strip "$i"; done;
greetings
xtenshisanx
  • Held Mitglied
  • Valkyrja
  • Kernel: 3.16
  • Desktop: XFCE
  • Branch: Testing
  • GPU Card: GTX 960
« Reply #12 on: 10. September 2013, 18:17:34 »
@xtenshisanx,
[/size]Thnx but I've tried it and it does not work.[/color]
@[/size]Ayceman[/color]
[/size]Thnx I'll give that a try a bit later on.[/color]
[/size][/color]
[/size]@[/color][/size]thundersqueak[/color]
Thnx, I also googled a lot and never found a solution. It's not a trainsmash as everything still works but the popups are annoying.
  • Held Mitglied
  • Valkyrja
  • Kernel: 3.16
  • Desktop: XFCE
  • Branch: Testing
  • GPU Card: GTX 960
« Reply #13 on: 11. September 2013, 14:52:05 »
Use this:
EDIT: This:
Code: [Select]
Ok just tried that and getting the same error plus a new one wrt permissions, see attached image.
Offline Ayceman
  • Core Team
  • Security Chief :P
  • Desktop: Xfce
  • Skill: Advanced
« Reply #14 on: 11. September 2013, 14:56:38 »
Permission error?! I'm stumped...
Well, I guess you could manually give it every permission you can...
There may be other files that have the incorrect sRGB profile, if they keep popping up, maybe in your home folder?
