Author Topic: Errors generating grub.cfg with latest update: "leaked on vgs invocation"  (Read 4327 times)
Offline cb474Topic starter
  • Vollwertiges Mitglied
With the latest updates in the stable repo, I'm getting a long series of "leaked on vgs invocation" errors, with the generation of grub.cfg:
Code: [Select]
(25/37) upgrading linux39                          [######################] 100%
>>> Updating module dependencies. Please wait ...
>>> Generating initial ramdisk, using mkinitcpio.  Please wait...
==> Building image from preset: /etc/mkinitcpio.d/linux39.preset: 'default'
  -> -k /boot/vmlinuz-39-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-39-x86_64.img
==> Starting build: 3.9.8-1-MANJARO
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [encrypt]
  -> Running build hook: [lvm2]
  -> Running build hook: [fsck]
==> Creating gzip initcpio image: /boot/initramfs-39-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux39.preset: 'fallback'
  -> -k /boot/vmlinuz-39-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-39-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: aic94xx
==> WARNING: Possibly missing firmware for module: bfa
==> Creating gzip initcpio image: /boot/initramfs-39-x86_64-fallback.img
Generating grub.cfg ...
File descriptor 3 (/var/log/pacman.log) leaked on vgs invocation. Parent PID 5253: /usr/bin/grub-probe
File descriptor 4 (/var/lib/pacman/db.lck) leaked on vgs invocation. Parent PID 5253: /usr/bin/grub-probe
File descriptor 5 (/home/user) leaked on vgs invocation. Parent PID 5253: /usr/bin/grub-probe
File descriptor 6 (socket:[18688]) leaked on vgs invocation. Parent PID 5253: /usr/bin/grub-probe
File descriptor 3 (/var/log/pacman.log) leaked on vgs invocation. Parent PID 5263: /usr/bin/grub-probe
File descriptor 4 (/var/lib/pacman/db.lck) leaked on vgs invocation. Parent PID 5263: /usr/bin/grub-probe
File descriptor 5 (/home/user) leaked on vgs invocation. Parent PID 5263: /usr/bin/grub-probe
File descriptor 6 (socket:[18688]) leaked on vgs invocation. Parent PID 5263: /usr/bin/grub-probe
File descriptor 3 (/var/log/pacman.log) leaked on vgs invocation. Parent PID 5273: /usr/bin/grub-probe
File descriptor 4 (/var/lib/pacman/db.lck) leaked on vgs invocation. Parent PID 5273: /usr/bin/grub-probe
File descriptor 5 (/home/user) leaked on vgs invocation. Parent PID 5273: /usr/bin/grub-probe
File descriptor 6 (socket:[18688]) leaked on vgs invocation. Parent PID 5273: /usr/bin/grub-probe
File descriptor 3 (/var/log/pacman.log) leaked on vgs invocation. Parent PID 5283: /usr/bin/grub-probe
File descriptor 4 (/var/lib/pacman/db.lck) leaked on vgs invocation. Parent PID 5283: /usr/bin/grub-probe
File descriptor 5 (/home/user) leaked on vgs invocation. Parent PID 5283: /usr/bin/grub-probe
File descriptor 6 (socket:[18688]) leaked on vgs invocation. Parent PID 5283: /usr/bin/grub-probe
File descriptor 3 (/var/log/pacman.log) leaked on vgs invocation. Parent PID 5299: /usr/bin/grub-probe
File descriptor 4 (/var/lib/pacman/db.lck) leaked on vgs invocation. Parent PID 5299: /usr/bin/grub-probe
File descriptor 5 (/home/user) leaked on vgs invocation. Parent PID 5299: /usr/bin/grub-probe
File descriptor 6 (socket:[18688]) leaked on vgs invocation. Parent PID 5299: /usr/bin/grub-probe
File descriptor 3 (/var/log/pacman.log) leaked on vgs invocation. Parent PID 5311: /usr/bin/grub-probe
File descriptor 4 (/var/lib/pacman/db.lck) leaked on vgs invocation. Parent PID 5311: /usr/bin/grub-probe
File descriptor 5 (/home/user) leaked on vgs invocation. Parent PID 5311: /usr/bin/grub-probe
File descriptor 6 (socket:[18688]) leaked on vgs invocation. Parent PID 5311: /usr/bin/grub-probe
Found linux image: /boot/vmlinuz-39-x86_64
Found initrd image: /boot/initramfs-39-x86_64.img
File descriptor 3 (/var/log/pacman.log) leaked on vgs invocation. Parent PID 5456: /usr/bin/grub-probe
File descriptor 4 (/var/lib/pacman/db.lck) leaked on vgs invocation. Parent PID 5456: /usr/bin/grub-probe
File descriptor 5 (/home/user) leaked on vgs invocation. Parent PID 5456: /usr/bin/grub-probe
File descriptor 6 (socket:[18688]) leaked on vgs invocation. Parent PID 5456: /usr/bin/grub-probe
Found Linux Mint Debian Edition (1) on /dev/mapper/volume_rootA
done
My system seems to startup and work okay though (so far). I searched around on Google, but can't really figure out what these errors are about. Can someone explain them? Should I be concerned? Thanks.
Online philm
  • Core Team
    • Manjaro Linux
  • Kernel: Maintainer - so all ;)
  • Desktop: XFCE
  • Branch: Unstable
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Skill: Guru
Don't worry. It is a problem of os-prober. Here an old quote way back from 2009:
Quote
Colin Watson commited now a fix to os-prober to silence them.
They don't cause any real problem.
But I don't close this report now, I check if we're leaking any file
descriptors.
Someone else on IRC reported today that even an inotify fd was leaked to
lvs, which is clearly not from us.
Thanks. Any reason I got these errors this time, but not with previous kernel upgrades (especially if this problem goes back to 2009)?
Online philm
  • Core Team
    • Manjaro Linux
  • Desktop: XFCE
  • Branch: Unstable
  • Skill: Guru
I don't know yet. The one back in 2009 was leaked on lvs invocation. The current one is now vgs. On my box I don't have this issue. It depends also on the filesystem you're using. If I know more I might post it.
Thanks. I'm using ext4. I have a separate /boot partition (ext4) and then my /root partition (ext4) on an encrypted lvm. Any other info that would be helpful?
Offline mkennedy150
  • Sr. Mitglied
  • Kernel: linux39-x64
  • Desktop: KDE
  • Branch: Stable
  • GPU Card: Intel 4000 HD
  • GPU driver: free
  • Skill: Intermediate
@philm it must bee lvm causing it I dunno why but that might help someone solve it.
Offline apaatsio
  • Neuling
  • Kernel: linux313-x64
  • Desktop: OpenBox 3.5.2
I was just seeing the same errors. I have encrypted ext4 too.
Just as an update, since it's been more than a year since I started this thread, I'm still having this issue. Glad to know I'm not alone, I guess.
