Author Topic: Easy2Boot: a new way for creaing a multiboot usb pendrive!  (Read 3502 times)
Offline tun in a cellar
  • Held Mitglied
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Hybrid graphic card (Intel/ATI)
  • GPU driver: free (the discrete card is switched off)
  • Kernel: linux313-x64 (the latest if possible)
  • Skill: Advanced
I don't know if I post at the right place...
Have a look at the Easy2boot tutorial
It is very helpfull
« Last Edit: 08. May 2013, 17:11:52 by Parmaster »
Why doing it yourself when manjaro-system can do it for you?
Offline mips
  • Held Mitglied
  • Valkyrja
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: GTX 960
  • GPU driver: video-nvidia
  • Kernel: 3.16
  • Skill: Intermediate
Re: Easy2Boot: a new way for creaing a multiboot usb pendrive!
« Reply #1 on: 08. May 2013, 19:06:22 »
Looks like a windows app?
  • Held Mitglied
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Advanced
« Reply #2 on: 08. May 2013, 20:25:01 »
1st of all: sorry for a typo in the link... here the fixed one.
Easy2Boot is a set of files to be installed in the root of a blank VFAT partition created on an usb drive.
This usb drive must be bootable via grub4dos
Indeed the original tutorial explains us how to install grub4dos from windows (my bad...)
Let me explain you how I performed:
Step1: Prepare the pendrive
create a single partition on an usb drive (keep in mind that partition table must be a MBR one)
create a VFAT file system on this partition
mount this partition (for instance mount /dev/sdc1 /run/media/pendrive)
Step2: Copy Easy2Boot files in the root of the pendrive
download Easy2Boot v1 BETA26 v6.
unzip the files and copy them in the root of the pendrive (for instance /run/media/pendrive)
Step3: Install Grub4Dos
download Grub4Dos
unzip the files somewhere ON YOUR COMPUTER (for instance ~/working/grub2dos)
run the following command from the working directory:
Code: [Select]
sudo ./bootlace.com --time-out=0 /dev/sdX
don't forget to replace sdX by the correct id (for instance sdc)
Step4: copy some iso files
copy some iso files in the "_ISO\AUTO" folder placed at the root of your pendrive
Boot the pendrive (using VirtualBox could be useful)
Choose the 2nd entry in the main menu (AUTO)
A autogenerated menu is displayed: there is one entry per iso file
Offline Kolibry
  • Sr. Mitglied
  • Branch: Unstable
  • Desktop: Openbox
  • GPU Card: Ati Radeon HD6290 Wrestler
  • GPU driver: free
  • Kernel: Linux manjaro 3.12.30-1
« Reply #3 on: 08. May 2013, 23:04:12 »
Thanks a lot for sharing, I tried it and this works very well, currently I can add very quickly (copy paste) new isos to the menu, I have Voyager, Chakra, Cinnarch and Manjaro at the same time :)
Asus 1225B - 11,6" -  AMD E-60 Dual Core 1,3Ghz - 4 Go RAM - HDD 1To-  Radeon HD6290
 Manjaro Openbox - Github
Offline mips
  • Held Mitglied
  • Valkyrja
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: GTX 960
  • Kernel: 3.16
« Reply #4 on: 08. May 2013, 23:38:27 »
<snip>
Does it require windows or not?
Online Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #5 on: 09. May 2013, 01:19:10 »
No need of Windows.
A good replacement for multisystem.  :)
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline mips
  • Held Mitglied
  • Valkyrja
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: GTX 960
  • Kernel: 3.16
« Reply #6 on: 09. May 2013, 13:15:03 »
No need of Windows.
This is a windows app,
Online Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #7 on: 09. May 2013, 13:25:02 »
I have an explanation, but in french, here.
Works with Ubuntu.
  • Held Mitglied
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Advanced
« Reply #8 on: 09. May 2013, 15:16:44 »
Yes but I did not use it...
In my post above, I explained how to install Grub4Dos from a linux system:
Code: [Select]
Please, trust me.
Type "Easy2Boot" in a web search tool and you will find this link
Edit: @Esclapion: I've just posted the link related to the english version  :P
« Last Edit: 09. May 2013, 15:21:26 by tun in a cellar »
Offline mips
  • Held Mitglied
  • Valkyrja
  • Branch: Testing
  • Desktop: XFCE
  • GPU Card: GTX 960
  • Kernel: 3.16
« Reply #9 on: 09. May 2013, 15:36:22 »
Ok, cool thanks!
