Author Topic: wifi adapter D-LINK DWA-131 rev. B1 working  (Read 7346 times)
0 Members and 2 Guests are viewing this topic.
Offline oriolfaTopic starter
  • Vollwertiges Mitglied
  • Desktop: Openbox
  • Branch: testing
  • GPU Card: nVidia Radeon
  • Skill: Novice
« on: 15. April 2013, 09:41:14 »
Hi everyone.
I bought a D-LINK Nano USB last friday and I expected to plug-in and start surfing...  ::) Instead, I've spent most of the weekend just to get it work, and found many info out there, so I want to share how I get it working in manjaro openbox. Must tell you I had never done a modprobe before, so maybe this instructions are obvious for some of you, but anyway...
The device is knowed as D-LINK DWA-131 rev B.1, using firmware 2.00, and it use the realtek chipset and the RTL8192CU driver
So, first we must have the driver loaded:
Code: [Select]
sudo modprobe rtl8192cu
After that, a
Code: [Select]
modinfo rtl8192cu should show you info about the driver.
At the moment of writting this, the D-LINK DWA-131 rev.B1 is not in the list of supported devices of the driver, so we must add it manually. To do so, we must know which vendor ID and product ID. As it's a usb device just type:
Code: [Select]
lsusb
That will show you something like "Bus 002 Device 004: ID 2001:330D D-Link System DWA-131". In this case 2001 is the vendor ID and 330D is the product ID,
And then, to add the product to the driver
Code: [Select]
echo "2001 330D" | sudo tee /sys/bus/usb/drivers/rtl8192cu/new_id
    After that line in the terminal, the blue led of the nano USB device should turn on, and we should be able to use it with nm-applet.
    To make this permanent on our system, we must:
    • Put the rtl8192cu module in the list of loaded modules. Just add "rtl8192cu" in /etc/modules-load.d/modules.conf
    • add the following command to /etc/rtc.local /etc/rc.local:
Code: [Select]
    This done the job for me, but the connection was not all the stable it should, so I upgrade my kernel to 3.9 and now it's more reliable. Hopefully in the near future all this stuff not will be necessary
    « Last Edit: 26. April 2014, 22:56:18 by oriolfa »
    Offline ArcNexus
    • Neuling
      • Maya GNU Software
    Re: wifi adapter D-LINK DWA-131 rev. B1 working
    « Reply #1 on: 04. April 2014, 23:37:49 »
    Sorry, excellent howto. But, in last step is /etc/rc.local:  not /etc/rtc.local:  :P
    Offline drponti
    • Neuling
    • Desktop: Openbox
    • GPU Card: Ati Mobility Radeon X700
    • Skill: Novice
    « Reply #2 on: 26. April 2014, 21:59:33 »
    I can't compile it, downloaded the driver from Realtek page:
    RTL8188C_8192C_USB_linux_v4.0.2_9000.20130911
    extracted it.
    Manual says to run ./install.sh
    I've tried many times but nothing happens.
    Can you help me ?
    • Desktop: Openbox
    • Branch: testing
    • Skill: Novice
    « Reply #3 on: 26. April 2014, 23:07:46 »
    @drponti:
    I think it is not necessary to install the driver, because it is included in the news kernels. You just need to load the driver with the modprobe command. Also you may want to try the AUR package dkms-8192cu, wich claims to include the driver for ralink 8192cu. I have not tried it, and sadly my dlink wifi stick stopped working, so I cannot make tests on it anymore.
    @ArcNexus: You're right. I've changed my post to correct it. Thanks!
