Author Topic: pacman 4.1 request  (Read 4954 times)
Offline z1lt0idTopic starter
  • Neuling
  • Branch: stable
  • Desktop: Awesome
  • GPU Card: Nvidia GS7600
  • GPU driver: Nouveau
  • Kernel: linux310-x86
  • Skill: Guru
pacman 4.1 request
« on: 05. April 2013, 00:53:10 »
Hi Devs,
Was wondering if you could put Pacman 4.1 from the Arch testing repos into the unstable repos of Manjaro.  I am find a lot of aur git packages will not compile now due to it having a pacman 4.1 dependency.
Online philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
Re: pacman 4.1 request
« Reply #1 on: 05. April 2013, 02:19:47 »
Well, we keep pacman 4.0-series for a while. We can't move to 4.1-series yet. A lot of our own tools depend on the old series.
Quote from: Guillaume Benoit
Yes we have to wait, libalpm 4.1 will break pamac. It seems that the new version of pyalpm supporting libalpm 4.1 is almost ready.
I will finish pamac 0.6 that use libalpm 4.0 and then I will port it to libalpm 4.1.
We have to adopt pacman 4.1 and the ported pamac as the same time in our repos to not break anything.
It will take some time until we have adopted to the new upstream changes. For the time being we will move some older packages to our addon repository and blacklist them, such as pacman from getting synced from Arch-Servers. Maybe a list of "broken" packages can be started so we can check what needed to be worked on ...
  • Neuling
  • Branch: stable
  • Desktop: Awesome
  • Skill: Guru
« Reply #2 on: 05. April 2013, 02:29:22 »
That is a shame.  Thanks anyway, guess I'll just have to wait.
Offline xircon
  • Held Mitglied
  • Branch: Unstable
  • Desktop: Plasma
  • GPU Card: Intel 4th gen
  • GPU driver: free
  • Kernel: Always the newest!
  • Skill: Advanced
« Reply #3 on: 12. April 2013, 09:29:03 »
"Broken" Packages so far:
granite-bzr
gala-bzr
lightdm-ubuntu
nemo-git
But I don't think lightdm-ubuntu problem is caused by pacman.
Cheers
Steve
Online philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #4 on: 13. April 2013, 12:33:15 »
pacman 4.1 landed now in unstable. Please report any issues you my find with it and pamac.
Offline xircon
  • Held Mitglied
  • Branch: Unstable
  • Desktop: Plasma
  • GPU driver: free
  • Skill: Advanced
« Reply #5 on: 13. April 2013, 12:35:43 »
Which repo is the main repo (first to update?). Only on my way to work in 20 minutes and I want to test :)
Cheers
Steve
Offline tun in a cellar
  • Held Mitglied
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Hybrid graphic card (Intel/ATI)
  • GPU driver: free (the discrete card is switched off)
  • Kernel: linux313-x64 (the latest if possible)
  • Skill: Advanced
« Reply #6 on: 13. April 2013, 12:52:24 »
I tried and failed:
package-query requires pacman<4.1
Additional question: What happens if I install pacman 4.1? Will pamac still work?
« Last Edit: 13. April 2013, 12:59:20 by tun in a cellar »
Why doing it yourself when manjaro-system can do it for you?
Offline ringo
  • Held Mitglied
  • www.manjaro-nl.org
    • Manjaro Belgium + forum
  • Branch: unsourced
  • Desktop: xfce
  • GPU Card: Nvidia Geforce 8600 GT (acer 23inch)
  • GPU driver: Free*
  • Kernel: linux kernel
  • Skill: Novice
« Reply #7 on: 13. April 2013, 13:05:04 »
yep here too ;)
Dutch go the dutch site :)
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #8 on: 13. April 2013, 13:14:01 »
package-query is needed by yaourt.... looking for yaourt through archlinux, no yaourt?
Offline xircon
  • Held Mitglied
  • Branch: Unstable
  • Desktop: Plasma
  • GPU driver: free
  • Skill: Advanced
« Reply #9 on: 13. April 2013, 13:14:42 »
Ringo - which mirror are you using, not got time to play now, must go to work
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #10 on: 13. April 2013, 13:21:58 »
french :)
yaourt has blocked....the update so i deleted yaourt and package-query :)
after that i couldnt find yaourt so i reinstall a newer yaourt version and package-query
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #11 on: 13. April 2013, 13:32:50 »
have compiled yaourt from archlinux ...only yeah it set manjaro-keyring to orphan.. so i have reinstalled but stil in orphan , have marked as Explicited again :)
so  pacman 4.1 updates need also new yaourt and package-query.., but i dont know in the other mirrors yaourt seems to be gone?
have compiled from here http://archlinux.fr/yaourt-en    ...
  • Held Mitglied
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Advanced
« Reply #12 on: 13. April 2013, 13:48:51 »
You will never found yaourt in official arch repo even if this package is popular in AUR.
Have a look [ur=https://wiki.archlinux.org/index.php/Yaourtl]here[/url]
Yaourt is developped and maintained by a French guy from the French community of Archlinux
I guess that yaourt was adapted in order to be pacman 4.1 complient.
I will try this:
switch to stable again
remove yaourt
switch to unstable
upgrade the system
wait for yaourt being updated
stay tuned...
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #13 on: 13. April 2013, 13:58:00 »
i have just remove it and install other one :o  in the repo isnt also
yaourt
Code: [Select]
[ringo@manjaro ~]$ sudo pacman -Si yaourt
error: package 'yaourt' was not found
[ringo@manjaro ~]$
pamac works ok, only on Orphan handling  as alo an option to make Explecite... and after some removal from orphanage it stuck for even try to replicate but didnt again... shall see furter it works..
  • Held Mitglied
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Advanced
« Reply #14 on: 13. April 2013, 13:59:44 »
Bingo!
After having switched to stable, removed yaourt (pacman -Rcsn yaourt) and switched to unstable, I coud installed pacman 4.1
pacman.conf.pacnew was created => let's have a look at it...
Stay tuned...
