Author Topic: [Update] 2014-08-15: Kernels, Nvidia, I-Nex, Flash, XFCE  (Read 2753 times)
Offline philmTopic starter
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« on: 15. August 2014, 21:56:51 »
:: Manjaro Update - 2014-08-15 - Update-Pack 7 RC1
I'm happy to present our first release candidate of Update-Pack 7!
With this we think linux316 is now ready for public use. This also means
linux315 is EOL and won't be supported by upstream anymore. Consider to switch
to the latest kernel version or one of our LTS kernels. Linux38 and Linux311
will be dropped soon as Canonical also will stop to support these kernel series
within this month.
With I-Nex we have a great application that gathers information for hardware
components available on your system and displays it using an user interface
similar to the popular Windows tool CPU-Z. I-Nex can display information for the
following components: CPU, GPU, Motherboard, Sound, Hard disks, RAM, Network and
USB as well as some system info like the hostname, Linux distribution and
version, Xorg, GCC, GLX versions and Linux Kernel info. Test out the brand new
release 7.4.0!
We also updated the proprietary Nvidia Driver to 340.32 which brings lot of
fixes and support for newer hardware.
Other than that, we have regular upstream updates and rebuilds by Archlinux.
Please report any issues you may find.
kind regards
Philip
:: Current supported kernels
 - Linux38  3.8.13.27 (EOL)
 - Linux310 3.10.53
 - Linux311 3.11.10.14 (EOL)
 - Linux312 3.12.26
 - Linux313 3.13.11.6
 - Linux314 3.14.17
 - Linux315 3.15.10 (EOL)
 - Linux316 3.16.1
:: Package changes
 - testing community i686:  93 new and 92 removed package(s)
 - testing community x86_64:  92 new and 91 removed package(s)
 - testing core i686:  21 new and 19 removed package(s)
 - testing core x86_64:  21 new and 19 removed package(s)
 - testing extra i686:  158 new and 133 removed package(s)
 - testing extra x86_64:  158 new and 133 removed package(s)
 - testing multilib x86_64:  9 new and 9 removed package(s)
« Last Edit: 22. August 2014, 23:19:55 by philm »
Offline carlo3
  • Vollwertiges Mitglied
  • multiboot system XP-LinuxMintCinnamon-ManjaroXFCE
  • Branch: testing
  • Desktop: xfce+compiz09
  • GPU Card: Intel G41
  • GPU driver: free
  • Kernel: linux319/41-x86
  • Skill: Novice
Re: [Update] 2014-08-15: Kernels, Nvidia, I-Nex, Flash, XFCE
« Reply #1 on: 15. August 2014, 23:43:15 »
gnight!
sorry but issues here with compiz-xfce and emerald when i switch to the new kernel linux316: the emerald theme and compiz are vanished..  ???
back to linux314 for now
Offline tulambin
  • Neuling
  • Manjaro Dev Team. Thank You for your hardwork
  • Branch: testing
  • Desktop: Cinnamon 2.6.13 (Gtk 3.18.2)
  • GPU Card: GT218 ION
  • Kernel: 4.2.3-1-MANJARO x86_64 (64 bit
  • Skill: Intermediate
« Reply #2 on: 16. August 2014, 02:02:55 »
Updated to 3.16.. no errors or warnings runs quicky quick and fart'in fast. Thanks Phil
Code: [Select]
System:    Host: acer Kernel: 3.16.1-1-MANJARO x86_64 (64 bit gcc: 4.9.1) Desktop: Cinnamon 2.2.14 (Gtk 3.12.2)
           Distro: ManjaroLinux 0.8.10 Ascella
Machine:   System: Acer product: Aspire R3700
           Mobo: Acer model: TPDS05 R3700 Bios: American Megatrends v: P01-A4 date: 04/26/2011
CPU:       Dual core Intel Atom D525 (-HT-MCP-) cache: 512 KB flags: (lm nx sse sse2 sse3 ssse3) bmips: 7185
           Clock Speeds: 1: 1795 MHz 2: 1795 MHz 3: 1795 MHz 4: 1795 MHz
Graphics:  Card: NVIDIA GT218 [ION] bus-ID: 01:00.0
           Display Server: X.Org 1.15.2 driver: nvidia Resolution: 1920x1080@60.00hz
           GLX Renderer: ION/PCIe/SSE2 GLX Version: 3.3.0 NVIDIA 340.32 Direct Rendering: Yes
Audio:     Card-1 Intel NM10/ICH7 Family High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
           Card-2 NVIDIA High Definition Audio Controller driver: snd_hda_intel bus-ID: 01:00.1
           Sound: Advanced Linux Sound Architecture v: k3.16.1-1-MANJARO
Network:   Card-1: Ralink RT3090 Wireless 802.11n 1T/1R PCIe driver: rt2800pci v: 2.3.0 bus-ID: 02:00.0
           IF: wls34 state: down mac: <filter>
           Card-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: e800 bus-ID: 03:00.0
           IF: ens35 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 320.1GB (10.3% used) ID-1: /dev/sda model: WDC_WD3200BEVT size: 320.1GB
Partition: ID-1: / size: 290G used: 28G (10%) fs: ext4 dev: /dev/sda3
           ID-2: /boot size: 249M used: 60M (25%) fs: ext2 dev: /dev/sda1
           ID-3: swap-1 size: 3.80GB used: 0.00GB (0%) fs: swap dev: /dev/sda2
Sensors:   None detected - is lm-sensors installed and configured?
Info:      Processes: 131 Uptime: 13 min Memory: 975.8/3956.9MB Init: systemd Gcc sys: 4.9.1
           Client: Shell (bash 4.3.221) inxi: 2.1.29
« Last Edit: 16. August 2014, 07:59:50 by FadeMind »
If at first you don't succeed. Skydiving is not for you!!!!
Offline carlo3
  • Branch: testing
  • GPU driver: free
  • Skill: Novice
« Reply #3 on: 16. August 2014, 07:11:55 »
just rebooted twice and now linux316 works properly  8)
Offline Erwan
  • Jr. Mitglied
  • Branch: unstable
  • Desktop: Xfce + Compiz
  • GPU Card: NVIDIA G84 [GeForce 8600 GS]
  • GPU driver: free/non-free
  • Kernel: Linux319 x86_64
« Reply #4 on: 16. August 2014, 11:30:45 »
I read that linux316 was a bad kernel. :-[ I just installed it and it works great, very fast thanks :)
I am always with Nvidia legacy. I have not tried the new 340 driver, you think that it works well with Compiz now?
« Last Edit: 16. August 2014, 11:34:38 by Erwan »
Offline amigo
  • Neuling
  • Branch: unstable
  • Desktop: KDE 4.14.0
  • GPU Card: AMD RADEON HD 6450
  • GPU driver: non-free driver
  • Kernel: Linux 3.17.0-1-MANJARO x86_64
  • Skill: Novice
« Reply #5 on: 16. August 2014, 11:45:56 »
Thanks Phil !
Code: [Select]
[amigo@computer ~]$ inxi -Fxz
System:    Host: computer Kernel: 3.16.1-1-MANJARO x86_64 (64 bit gcc: 4.9.1)
           Desktop: KDE 4.13.3 (Qt 4.8.6)
Machine:   Mobo: ASUSTeK model: P8H61-M LX2 v: Rev X.0x
           Bios: American Megatrends v: 0217 date: 04/15/2011
CPU:       Dual core Intel Pentium G620 (-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 10380
           Clock Speeds: 1: 1612 MHz 2: 1694 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Caicos [Radeon HD 6450/7450/8450 / R5 230 OEM]
           bus-ID: 01:00.0
           Display Server: X.Org 1.15.2 driver: fglrx
           Resolution: 1024x768@85.00hz
           GLX Renderer: AMD RADEON HD 6450
           GLX Version: 4.4.12874 - CPC 14.10.1006.1001 Direct Rendering: Yes
Audio:     Card-1 Advanced Micro Devices [AMD/ATI] Caicos HDMI Audio [Radeon HD 6400 Series]
           Card-2 Intel 6 Series/C200 Series Family High Definition Audio Controller
           Sound: ALSA v: k3.16.1-1-MANJARO
Network:   Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: d000
           bus-ID: 06:00.0
           IF: enp6s0 state: down mac: <filter>
Drives:    HDD Total Size: 2128.4GB (20.5% used)
           ID-1: /dev/sdc model: WDC_WD15EARS size: 1500.3GB
           ID-2: /dev/sda model: OCZ size: 128.0GB
           ID-3: /dev/sdb model: WDC_WD5000AAKX size: 500.1GB
           ID-1: / size: 39G used: 7.8G (21%) fs: ext4 dev: /dev/sda1
           ID-2: /home size: 79G used: 1.2G (2%) fs: ext4 dev: /dev/sda2
           ID-3: swap-1 size: 4.68GB used: 0.00GB (0%) fs: swap dev: /dev/sdb8
Sensors:   System Temperatures: cpu: 50.0C mobo: N/A
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 143 Uptime: 1:24 Memory: 930.0/3940.3MB
[amigo@computer ~]$ systemd-analyze
Startup finished in 1.896s (kernel) + 3.538s (userspace) = 5.434s
[amigo@computer ~]$
« Last Edit: 16. August 2014, 11:49:47 by amigo »
Offline andrewb
  • Jr. Mitglied
  • Manjaro works as Arch should. Without the worry
  • Branch: testing
  • Desktop: XFCE(Compiz+emerald)
  • GPU Card: AMD Radeon HD 8610G
  • GPU driver: non-Free
  • Kernel: 3.14.4-1-MANJARO
« Reply #6 on: 16. August 2014, 20:12:05 »
Another flawless update. Colors for some reason look a little more vibrant and pop a little more with kernel 3.16. Not sure why but I like it.
Manjaro is the best, most customizable and easy distro.
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #7 on: 17. August 2014, 14:07:23 »
I think this update doesn't need so much testing. Expect it in our stable branch soon.
Offline Uncle Spellbinder
  • IPA!
    • Hallucination Layer
  • Branch: Testing
  • Desktop: KDE
  • GPU Card: AMD Kaveri Quad-Core A10-7800 Radeon R7 Series
  • GPU driver: Non-Free
  • Kernel: x86_64 Linux 4.1.19-1-MANJARO
« Reply #8 on: 17. August 2014, 17:26:09 »
Flawless update here as well. Installed 3.16 and I must admit that it does feel snappier, more "pop".
in Any event, a perfect update for me.
“Without deviation from the norm, progress is not possible.” -  Frank Zappa
Offline eduardo
  • Sr. Mitglied
  • Branch: testing
  • Desktop: KDE plasma 5
  • GPU Card: Intel HDGraphics 4400 / Nvidia Geforce 960M
  • GPU driver: non-free on nvidia
  • Kernel: linux44, linux45_RC
  • Skill: Novice
« Reply #9 on: 18. August 2014, 07:00:30 »
Now the fan in my laptop is busier since I started using kernel 3.16. It's warmer.
Other than that everything seems to be ok
Offline agnotek
  • Jr. Mitglied
  • Branch: stable
  • Desktop: Cinnamon
  • GPU Card: Geforce 840M
  • GPU driver: free
  • Kernel: linux40
  • Skill: Advanced
« Reply #10 on: 19. August 2014, 15:09:55 »
I've got 1 big Problem with the 3.16.x Kernels
Using Cinnamon everything from the stable repo besides the linux316 stuff,
then I noticed that it takes up to 4-5 tries to get it up running normal.
Most of the time I get a Message directley after initramdisk... 3.16.1... that there's an error with loading something with the i915 GPU.
I can log in, but Cinnamon tells me it's running in Software Rendering Mode.
Never had this Problem with 3.15 Kernels or older.
I'm using an Acer TravelMate 5735Z, with an Intel GM45 Chipset
added the option: i915.invert_brightness=1 to Grub Cmdline to have a working display. Never had any problems with that.
Any Solutions, Conclusions?
PS: here's the output:
Code: [Select]
[    1.056690] [drm:init_ring_common] *ERROR* render ring initialization failed ctl 0001f001 (valid? 1) head 00000298 tail 00000000 start 00303000 [expected 00303000]
[    1.056701] [drm:i915_gem_init] *ERROR* Failed to initialize GPU, declaring it wedged
Code: [Select]
System:    Host: Manjaro-Cinnamon Kernel: 3.16.1-1-MANJARO x86_64 (64 bit gcc: 4.9.1)
Machine:   Mobo: Acer model: BA51_MV v: V1.14
           Bios: Acer v: V1.14 date: 07/26/2011
CPU:       Dual core Pentium T4500 (-MCP-) cache: 1024 KB
           flags: (lm nx sse sse2 sse3 ssse3) bmips: 9178
           Clock Speeds: 1: 1600 MHz 2: 1200 MHz
Graphics:  Card: Intel Mobile 4 Series Integrated Graphics Controller
           bus-ID: 00:02.0
           Display Server: X.Org 1.15.2 driver: intel
           Resolution: 1366x768@59.97hz
           GLX Renderer: Mesa DRI Mobile Intel GM45 Express
           GLX Version: 2.1 Mesa 10.2.5 Direct Rendering: Yes
Audio:     Card Intel 82801I (ICH9 Family) HD Audio Controller
Network:   Card-1: Broadcom BCM43225 802.11b/g/n driver: wl bus-ID: 04:00.0
           IF: wlp4s0 state: up mac: <filter>
           Card-2: Broadcom NetLink BCM57780 Gigabit Ethernet PCIe
           driver: tg3 v: 3.137 bus-ID: 05:00.0
           IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 500.1GB (66.3% used)
           ID-1: /dev/sda model: ST500LM000 size: 500.1GB
Partition: ID-1: / size: 20G used: 14G (71%) fs: ext4 dev: /dev/sda2
           ID-2: /home size: 4.7G used: 3.6G (77%) fs: ext4 dev: /dev/sda6
           ID-3: swap-1 size: 6.92GB used: 0.00GB (0%) fs: swap dev: /dev/sda7
Sensors:   System Temperatures: cpu: 52.0C mobo: N/A
Info:      Processes: 174 Uptime: 16 min Memory: 1501.8/3886.7MB
           Client: Shell (bash 4.3.181) inxi: 2.1.28
« Last Edit: 19. August 2014, 15:35:43 by agnotek »
Offline Sami-Perkele
  • Jr. Mitglied
  • Branch: testing
  • Desktop: KDE (net install)
  • GPU Card: AMD Radeon HD 6290
  • GPU driver: Catalyst
  • Kernel: linux314-x64
« Reply #11 on: 20. August 2014, 21:03:42 »
Somewhere in last weekend’s updates (testing repo) might have been something that broke the Catalyst drivers for me. Whenever the screen turned off, it could not be turned on again. Computer responded to nothing (might have been because of the screenlock that was on) and so I had to do hard reboot. I tried with three different kernels (3.10, 3.14 and 3.16). This happened multiple times. And this has happened never before the weekend.
Downgrading the laptop-mode-tools (because it was newer than in repositories) did not help.
It was not about suspending, because my computer was not set to suspend or hibernate. Also, lights were on as normal and fan was spinning.
I changed to the free ATI drivers and the problem is gone.
« Last Edit: 20. August 2014, 21:38:13 by Sami-Perkele »
Offline Lukimya
  • Held Mitglied
  • Branch: Unstable
  • Desktop: Gnome 3.20x
  • GPU Card: Intel HD4400
  • GPU driver: free
  • Kernel: 4.4.5-1-ARCH
« Reply #12 on: 20. August 2014, 21:49:09 »
All is working good for me.
Offline agnotek
  • Jr. Mitglied
  • Branch: stable
  • Desktop: Cinnamon
  • GPU driver: free
  • Kernel: linux40
  • Skill: Advanced
« Reply #13 on: 22. August 2014, 16:48:39 »
Tried the same Kernel on the same Notebook with the same LM & DE (Unity & Cinnamon) with Ubuntu 14.04, no problems there.
So it has to be a Bug in the Manjaro Kernel of 3.16.x
