Author Topic: Update failure using pacman  (Read 397 times)
Offline MoTopic starter
  • Neuling
  • Skill: Novice
« on: 08. March 2014, 20:08:21 »
Hi guys I have problem updating my system using pacman; I get the following error when trying to update my system using the
sudo pacman -Syyu
Code: [Select]
[shaakier@ManjaroXFCE ~]$ sudo pacman -Syyu
error: failed to update core (unable to lock database)
error: failed to update extra (unable to lock database)
error: failed to update community (unable to lock database)
error: failed to update multilib (unable to lock database)
error: failed to synchronize any databases
error: failed to init transaction (unable to lock database)
error: could not lock database: File exists
  if you're sure a package manager is not already
  running, you can remove /var/lib/pacman/db.lck
Please note that I did use the sudo pacman-mirrors -g command before the sudo pacman -Syyu
Please can you advise me :)
kind regards
Mo
Offline Hertz
  • Held Mitglied
  • Skill: Novice
Re: Update failure using pacman
« Reply #1 on: 08. March 2014, 20:26:52 »
Hi Mo,
have you change the Branch stable, testing or Unstable in /etc/pacman-mirrors.conf???
  • Neuling
  • Skill: Novice
« Reply #2 on: 08. March 2014, 20:33:53 »
Hi Hertz
Seems you operating on a very fast frequency, judging from your fast reply on this forum ;D
I did not change anything in terms of branches in  /etc/pacman-mirrors.conf
Offline ringo
  • Support Team
  • #manjaro IRC admin.
    • Manjaro Belgium + forum
  • Kernel: linux 4.1
  • Desktop: Cinnamon
  • Branch: unstable
  • GPU Card: Nvidia Geforce 8600 GT (acer 23inch)
  • GPU driver: Free*
  • Skill: Intermediate
« Reply #3 on: 08. March 2014, 20:35:41 »
hi !
check this you see in your out put
Code: [Select]
do :
Code: [Select]
sudo rm /var/lib/pacman/db.lck
eventually sudo pacman-mirrors -g
but sudo pacman -Syyu wil do?
Checkout #manjaro direct support. irc.manjaro-nl.org
Offline Hertz
  • Held Mitglied
  • Skill: Novice
« Reply #4 on: 08. March 2014, 20:50:06 »
Hi Hertz
Hi Mo,
Yes i am always lurking  ;D
  • Neuling
  • Skill: Novice
« Reply #5 on: 08. March 2014, 21:09:03 »
THANK YOU
ringo32 and Hertz.
Your code worked ringo32; my system has updated successfully.
Kind REGARDS
Mo 8)
