Author Topic: Video Player problems and solutions Parole Totem VLC  (Read 1414 times)
Offline darkcityTopic starter
  • Neuling
  • Branch: stable
  • Desktop: Openbox
  • GPU Card: [AMD/ATI] RV100 [Radeon 7000 / Radeon VE]
  • GPU driver: radeon
  • Kernel: Linux 3.10.13-1-MANJARO (x86_64)
  • Skill: Novice
« on: 05. March 2014, 21:04:14 »
Evening all,
Recently on Manjaro Openbox 64bit (AMD),  I wanted to play an .AVI file from a DVD data disc.
Dependencies for Parole media player
Using Parole media player resulted in "missing pluging required, mpeg layer 3, install?".  When I clicked to install nothing happen.  I tried installing all the MP3 related libraries I could find - to no avail.
However, after installing Totem - Totem AND and Parole could play the .AVI - so the dependency must be associated with Totem, not sure which one?
Totem - desktop integration
As mentioned I installed Totem media player.  However, it appears to include no desktop integration.  It doesn't show in the Openbox menu.  In Thunar under /usr/share/applications/ the totem.desktop file is hidden.  How can I get to the .desktop and make it show in the menu.
VLC - Bus error
I had VLC installed, but now it won't run.  It gives "Bus error, (core dump)" when run in the terminal.  I tried to uninstall and reinstall.  Now I get the Bus error when I try to reinstall.  Any ideas, could it be related to a corrupt harddrive.  Or maybe it could be related to install other software lke mixxx.
Online Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Desktop: Xfce+Compiz
  • GPU Card: nVidia GTX560Ti
  • GPU driver: non-free
  • Kernel: linux314 x64
  • Skill: Advanced
Re: Video Player problems and solutions Parole Totem VLC
« Reply #1 on: 06. March 2014, 01:43:37 »
VLC - Bus error
Please run vlc from a terminal like this:
Code: [Select]
vlc -vvvand post the output.
  • Neuling
  • Branch: stable
  • Desktop: Openbox
  • Skill: Novice
« Reply #2 on: 12. March 2014, 19:00:26 »
Thanks for the reply, Ive been away from the Manjaro machine.  I updated my packages with Octopi and now VLC runs no problem and with .AVI.
anyhow here is the vlc -vvv output just for reference.
Code: [Select]
VLC media player 2.1.4 Rincewind (revision 2.1.4-0-g2a072be)
[0x2121058] main libvlc debug: VLC media player - 2.1.4 Rincewind
[0x2121058] main libvlc debug: Copyright © 1996-2014 the VideoLAN team
[0x2121058] main libvlc debug: revision 2.1.4-0-g2a072be
[0x2121058] main libvlc debug: configured with ./configure  '--prefix=/usr' '--sysconfdir=/etc' '--disable-rpath' '--enable-faad' '--enable-nls' '--enable-lirc' '--enable-ncurses' '--enable-realrtsp' '--enable-aa' '--enable-vcdx' '--enable-upnp' '--enable-opus' '--enable-sftp' 'LUAC=/usr/bin/luac' 'LUA_LIBS=-llua -lm ' 'RCC=/usr/bin/rcc-qt4' 'CFLAGS=-I/usr/include/samba-4.0' 'LDFLAGS=-Wl,-O1,--sort-common,--as-needed,-z,relro' 'CPPFLAGS=-I/usr/include/samba-4.0' 'CXXFLAGS=-march=x86-64 -mtune=generic -O2 -pipe -fstack-protector --param=ssp-buffer-size=4'
[0x2121058] main libvlc debug: searching plug-in modules
[0x2121058] main libvlc debug: loading plugins cache file /usr/lib/vlc/plugins/plugins.dat
[0x2121058] main libvlc debug: recursively browsing `/usr/lib/vlc/plugins'
[0x2121058] main libvlc debug: saving plugins cache /usr/lib/vlc/plugins/plugins.dat
[0x2121058] main libvlc debug: plug-ins loaded: 425 modules
[0x2121058] main libvlc debug: opening config file (/home/potato/.config/vlc/vlcrc)
[0x2121058] main libvlc debug: translation test: code is "en_GB"
[0x2121058] main libvlc debug: CPU has capabilities MMX MMXEXT SSE SSE2 SSE3 3DNow! FPU
[0x2218dc8] main input debug: Creating an input for 'Media Library'
[0x2218dc8] main input debug: Input is a meta file: disabling unneeded options
[0x2218dc8] main input debug: using timeshift granularity of 50 MiB, in path '/tmp'
[0x2218dc8] main input debug: `file/xspf-open:///home/potato/.local/share/vlc/ml.xspf' gives access `file' demux `xspf-open' path `/home/potato/.local/share/vlc/ml.xspf'
[0x2218dc8] main input debug: creating demux: access='file' demux='xspf-open' location='/home/potato/.local/share/vlc/ml.xspf' file='/home/potato/.local/share/vlc/ml.xspf'
[0x221eba8] main demux debug: looking for access_demux module matching "file": 19 candidates
[0x221eba8] main demux debug: no access_demux modules matched
[0x2218dc8] main input debug: creating access 'file' location='/home/potato/.local/share/vlc/ml.xspf', path='/home/potato/.local/share/vlc/ml.xspf'
[0x2223ed8] main access debug: looking for access module matching "file": 26 candidates
[0x2223ed8] filesystem access debug: opening file `/home/potato/.local/share/vlc/ml.xspf'
[0x2223ed8] main access debug: using access module "filesystem"
[0x2224c98] main stream debug: Using stream method for AStream*
[0x2224c98] main stream debug: starting pre-buffering
[0x2224c98] main stream debug: received first data after 0 ms
[0x2224c98] main stream debug: pre-buffering done 296 bytes in 0s - 1497 KiB/s
[0x2224ef8] main stream debug: looking for stream_filter module matching "any": 9 candidates
[0x2224ef8] main stream debug: no stream_filter modules matched
[0x2224ef8] main stream debug: looking for stream_filter module matching "record": 9 candidates
[0x2224ef8] main stream debug: using stream_filter module "record"
[0x222ad68] main demux debug: looking for demux module matching "xspf-open": 63 candidates
[0x222ad68] playlist demux debug: using XSPF playlist reader
[0x222ad68] main demux debug: using demux module "playlist"
[0x222af48] main demux meta debug: looking for meta reader module matching "any": 2 candidates
[0x222af48] lua demux meta debug: Trying Lua scripts in /home/potato/.local/share/vlc/lua/meta/reader
[0x222af48] lua demux meta debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/reader
[0x222af48] lua demux meta debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/reader/filename.luac
[0x222af48] lua demux meta debug: Trying Lua scripts in /usr/share/vlc/lua/meta/reader
[0x222af48] main demux meta debug: no meta reader modules matched
[0x2218dc8] main input debug: `file/xspf-open:///home/potato/.local/share/vlc/ml.xspf' successfully opened
[0x223dd38] main xml reader debug: looking for xml reader module matching "any": 1 candidates
[0x223dd38] main xml reader debug: using xml reader module "xml"
[0x222ad68] playlist demux debug: parsed 0 tracks successfully
[0x2218dc8] main input debug: EOF reached
[0x222ad68] main demux debug: removing module "playlist"
[0x2224ef8] main stream debug: removing module "record"
[0x2223ed8] main access debug: removing module "filesystem"
[0x2216818] main playlist debug: creating audio output
[0x2224c98] main audio output debug: looking for audio output module matching "any": 6 candidates
[0x2224c98] pulse audio output debug: using library version 4.0.0
[0x2224c98] pulse audio output debug:  (compiled with version 4.0.0, protocol 28)
[0x2224c98] pulse audio output debug: connected locally to unix:/run/user/1000/pulse/native as client #16
[0x2224c98] pulse audio output debug: using protocol 28, server protocol 28
[0x2224c98] main audio output debug: using audio output module "pulse"
[0x2216818] main playlist debug: keeping audio output
[0x223a128] main interface debug: looking for interface module matching "hotkeys,none": 18 candidates
[0x223a128] main interface debug: using interface module "hotkeys"
[0x223aa08] main interface debug: looking for interface module matching "globalhotkeys,none": 18 candidates
[0x2224c98] pulse audio output debug: adding sink 0: alsa_output.pci-0000_00_14.2.analog-stereo (Built-in Audio Analog Stereo)
[0x223aa08] main interface debug: using interface module "globalhotkeys"
[0x223b9c8] main interface debug: looking for interface module matching "dbus,none": 18 candidates
[0x223b9c8] dbus interface debug: listening on dbus as: org.mpris.MediaPlayer2.vlc.instance9075
[0x223b9c8] main interface debug: using interface module "dbus"
[0x2121058] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[0x22448e8] main interface debug: looking for interface module matching "any": 18 candidates
[0x7fca802a2428] main generic debug: looking for extension module matching "any": 1 candidates
[0x7fca802a2428] lua generic debug: Opening Lua Extension module
[0x7fca802a2428] lua generic debug: Trying Lua scripts in /home/potato/.local/share/vlc/lua/extensions
[0x7fca802a2428] lua generic debug: Trying Lua scripts in /usr/lib/vlc/lua/extensions
[0x7fca802a2428] lua generic debug: Trying Lua playlist script /usr/lib/vlc/lua/extensions/VLSub.luac
[0x7fca802a2428] lua generic debug: Scanning Lua script /usr/lib/vlc/lua/extensions/VLSub.luac
[0x7fca802a2428] lua generic debug: Script /usr/lib/vlc/lua/extensions/VLSub.luac has the following capability flags: 0x5
[0x7fca802a2428] lua generic debug: Trying Lua scripts in /usr/share/vlc/lua/extensions
[0x7fca802a2428] main generic debug: using extension module "lua"
[0x22448e8] main interface debug: using interface module "qt4"
[0x2121058] main libvlc debug: exiting
[0x2121058] main libvlc debug: removing all interfaces
[0x22448e8] main interface debug: removing module "qt4"
[0x2216818] main playlist debug: deactivating the playlist
[0x2224c98] main audio output debug: removing module "pulse"
[0x22448e8] qt4 interface debug: requesting exit...
[0x22448e8] qt4 interface debug: waiting for UI thread...
[0x22448e8] qt4 interface debug: QApp exec() finished
[0x22448e8] qt4 interface debug: Video is not needed anymore
[0x22448e8] qt4 interface debug: Killing extension dialog provider
[0x22448e8] qt4 interface debug: ExtensionsDialogProvider is quitting...
[0x7fca802a2428] main generic debug: removing module "lua"
[0x7fca802a2428] lua generic debug: Deactivating all loaded extensions
[0x7fca802a2428] lua generic debug: All extensions are now deactivated
[0x223b9c8] main interface debug: removing module "dbus"
[0x223aa08] main interface debug: removing module "globalhotkeys"
[0x223a128] main interface debug: removing module "hotkeys"
[0x2216818] main playlist debug: destroying
[0x2240c58] main playlist export debug: saving Media Library to file /home/potato/.local/share/vlc/ml.xspf
[0x2240c58] main playlist export debug: looking for playlist export module matching "export-xspf": 4 candidates
[0x2240c58] main playlist export debug: using playlist export module "export"
[0x2240c58] main playlist export debug: removing module "export"
[0x2121058] main libvlc debug: removing stats
Offline dongogo
  • Neuling
    • gimpitalia.it
  • Branch: stable
  • Desktop: xcfe
  • GPU Card: nvidia GT 8600
  • GPU driver: non-free driver
  • Kernel: linux38-x64
« Reply #3 on: 11. June 2014, 21:49:37 »
I have reinstalled vlc
Code: [Select]
[donato@manjaro ~]$ sudo pacman -S vlc
Pacchetti (1): vlc-2.1.4-2
Dimensione totale dei pacchetti da installare:   43,18 MiB
:: Vuoi procedere con l'installazione? [S/n] s
(1/1) verifica delle chiavi presenti nel porta...  [######################] 100%
(1/1) verifica dell'integrit√† dei pacchetti        [######################] 100%
(1/1) caricamento dei file dei pacchetti           [######################] 100%
(1/1) controllo dei conflitti in corso             [######################] 100%
(1/1) controllo dello spazio disponibile sul d...  [######################] 100%
(1/1) installazione in corso di vlc                [######################] 100%
/tmp/alpm_Ry0UqA/.INSTALL: riga 1:  1203 Errore di segmentazione (core dump creato) usr/lib/vlc/vlc-cache-gen -f /usr/lib/vlc/plugins
Dipendenze opzionali di vlc
    avahi: for service discovery using bonjour protocol [installato]
    libnotify: for notification plugin [installato]
    ncurses: for ncurses interface support [installato]
    libdvdcss: for decoding encrypted DVDs [installato]
    lirc-utils: for lirc plugin
    libavc1394: for devices using the 1394ta AV/C [installato]
    libdc1394: for IEEE 1394 plugin [installato]
    kdelibs: KDE Solid hardware integration
    libva-vdpau-driver: vdpau back-end for nvidia
    libva-intel-driver: back-end for intel cards
    libbluray: for Blu-Ray support [installato]
    flac: for Free Lossless Audio Codec plugin [installato]
    portaudio: for portaudio support
    twolame: for TwoLAME mpeg2 encoder plugin
    projectm: for ProjectM visualisation plugin [installato]
    libcaca: for colored ASCII art video output [installato]
    libgme: for libgme plugin [installato]
    librsvg: for SVG plugin [installato]
    gnome-vfs: for GNOME Virtual File System support [installato]
    libgoom2: for libgoom plugin
    vcdimager: navigate VCD with libvcdinfo
    aalib: for ASCII art plugin [installato]
    libmtp: for MTP devices support [installato]
    smbclient: for SMB access plugin [installato]
    libcdio: for audio CD playback support [installato]
    ttf-freefont: for subtitle font
    ttf-dejavu: for subtitle font [installato]
    opus: for opus support [installato]
    libssh2: for sftp support [installato]
    lua-socket: for http interface
but I have this problem
Code: [Select]
[donato@manjaro ~]$ vlc -vvv
[0x1bbf118] main libvlc debug: VLC media player - 2.1.4 Rincewind
[0x1bbf118] main libvlc debug: Copyright © 1996-2014 the VideoLAN team
[0x1bbf118] main libvlc debug: revision 2.1.4-0-g2a072be
[0x1bbf118] main libvlc debug: configured with ./configure  '--prefix=/usr' '--sysconfdir=/etc' '--disable-rpath' '--enable-faad' '--enable-nls' '--enable-lirc' '--enable-ncurses' '--enable-realrtsp' '--enable-aa' '--enable-vcdx' '--enable-upnp' '--enable-opus' '--enable-sftp' 'LUAC=/usr/bin/luac' 'LUA_LIBS=-llua -lm ' 'RCC=/usr/bin/rcc-qt4' 'CFLAGS=-march=x86-64 -mtune=generic -O2 -pipe -fstack-protector --param=ssp-buffer-size=4 -I/usr/include/samba-4.0' 'LDFLAGS=-Wl,-O1,--sort-common,--as-needed,-z,relro' 'CPPFLAGS=-D_FORTIFY_SOURCE=2 -I/usr/include/samba-4.0' 'CXXFLAGS=-march=x86-64 -mtune=generic -O2 -pipe -fstack-protector --param=ssp-buffer-size=4'
[0x1bbf118] main libvlc debug: searching plug-in modules
[0x1bbf118] main libvlc debug: loading plugins cache file /usr/lib/vlc/plugins/plugins.dat
[0x1bbf118] main libvlc warning: cannot read /usr/lib/vlc/plugins/plugins.dat (No such file or directory)
[0x1bbf118] main libvlc debug: recursively browsing `/usr/lib/vlc/plugins'
[0x1bbf118] main libvlc warning: cannot load module `/usr/lib/vlc/plugins/codec/libtwolame_plugin.so' (libtwolame.so.0: impossibile aprire il file oggetto condiviso: File o directory non esistente)
[0x1bbf118] main libvlc warning: cannot load module `/usr/lib/vlc/plugins/control/liblirc_plugin.so' (liblirc_client.so.0: impossibile aprire il file oggetto condiviso: File o directory non esistente)
[0x1bbf118] main libvlc warning: cannot load module `/usr/lib/vlc/plugins/visualization/libgoom_plugin.so' (libgoom2.so.0: impossibile aprire il file oggetto condiviso: File o directory non esistente)
[0x1bbf118] main libvlc warning: cannot load module `/usr/lib/vlc/plugins/access/libvcdx_plugin.so' (libvcdinfo.so.0: impossibile aprire il file oggetto condiviso: File o directory non esistente)
[donato@manjaro ~]$
