Author Topic: Boot Manjaro iso image from a USB flash drive  (Read 11161 times)
Offline Fab_
  • Neuling
« on: 30. November 2012, 16:37:32 »
Hi,
Is it possible to boot the iso image from a USB flash drive?
Actually, I do that very often with lot of other linux distributions, using dd command or UNetbootin (http://unetbootin.sourceforge.net/) from Linux, Universal USB Installer (http://www.pendrivelinux.com/universal-usb-installer-easy-as-1-2-3/) or LinuxLive USB Creator http://www.linuxliveusb.com/ from Windows, but all these solutions failed with Manjaro!
Do you have any solution? Can you make the USB iso usable with these tools?
Thanks,
Fab_
Offline knowguy
  • Neuling
Re: Boot Manjaro iso image from a USB flash drive
« Reply #1 on: 30. November 2012, 17:25:42 »
You'll have to use Win32 Disk Imager, its kinda cruddy compared to all of the USB programs you've listed above but it does work. Here is the link: https://launchpad.net/win32-image-writer
Offline gerinho
  • Neuling
« Reply #2 on: 30. November 2012, 22:25:14 »
USBTransfer will do the job fine  :)
http://blog.oguzkirat.com/usb-transfer/
Offline cumali
  • Support Team
    • http://www.manjaro-tr.org/
  • Branch: stable
  • Desktop: Manjarobox, Xfce
  • GPU Card: İntel
  • GPU driver: free
  • Kernel: Linux38-x86
  • Skill: Novice
« Reply #3 on: 30. November 2012, 22:54:49 »
Offline fabdo
  • Vollwertiges Mitglied
    • fabdo.net
  • Branch: stable
  • Desktop: Xfce
  • GPU Card: NVIDIA GTX 750
  • GPU driver: Dual core AMD Phenom II X2 550
  • Kernel: 4.4.8
  • Skill: Intermediate
« Reply #4 on: 01. December 2012, 16:35:10 »
but can i do also with the "imagewriter" an persistent live-usb?
this would be cool! some ideas how to do that?
Desktop: Xfce, 64bit, NVIDIA, nonfree, linux448 (testing)
Laptop: Xfce, 64bit, ATI, free, linux448 (stable)
http://fabdo.net
Offline vanlong441
  • Artwork Team
  • Skill: Novice
« Reply #5 on: 01. December 2012, 17:28:57 »
in Windows you can do this:
+ Download www.chrysocome.net/downloads/dd-0.5.zip
+ Once installed, open the command prompt and do this:
Code: [Select]
dd.exe if=/path/to/the/downloaded/iso of=/path/to/the/USB/device
Read more about it here http://www.chrysocome.net/dd
Offline kwisher
  • Neuling
  • Skill: Novice
« Reply #6 on: 01. March 2016, 19:18:46 »
So I needed to create a USB boot for a friend today. I followed all suggestions from here (https://wiki.manjaro.org/index.php?title=Burn_an_ISO_File) with no luck at all. I even tried all the suggestions using Windows without success. I finally broke down and burned the ISO (15.12 XFCE 64-bit) to DVD and was able to boot to Manjaro.
C'mon folks, I am a seasoned Linux user and if I can't created a bootable USB, how do you expect new users coming from Windows or other Linux users wanting to try another distro? I promote Manjaro whenever I can and I will hate to tell someone who can't create a USB boot to try another distro.
Online eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #7 on: 01. March 2016, 19:26:13 »
@kwisher, being an experienced Linux user you should know that different hardware can have different issues. On most machines I can boot from (micro) SD cards, but on some not. You didn't tell anything about the machine, do other distros boot from USB sticks on it? I have an old AMD PC which cannot boot from a USB stick, any distro, but it boots from CD/DVD. Nothing special.
« Last Edit: 01. March 2016, 19:28:55 by eugen-b »
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • GPU Card: Intel HD4400M CPU: Core i7-4510U
  • GPU driver: Intel/Free
  • Kernel: 4.4-lts & 4.5
  • Skill: Novice
« Reply #8 on: 01. March 2016, 19:26:53 »
Few others seem to have your problems. Why is that?
Regards
“What, me worry?” ― Alfred E. Newman
Manjaro Wiki: https://wiki.manjaro.org/
Arch Wiki: https://wiki.archlinux.org/
Pacman Rosetta: https://wiki.archlinux.org/index.php/Pacman/Rosetta
Offline kwisher
  • Neuling
  • Skill: Novice
« Reply #9 on: 01. March 2016, 20:37:19 »
Same hardware, Dell Optiplex 790 & Latitude 5520, boots fine from USB using Xubuntu, Mint, etc.
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • Skill: Novice
« Reply #10 on: 02. March 2016, 14:04:08 »
Ubuntu-based distros ternd to use use a different ISO structure. Things like  Unetbootin will work for them, but not for Arch-based distros.
Offline PH
  • Branch: Stable
  • Desktop: XFCE
  • GPU Card: Intel Corporation
  • GPU driver: Non-Free
  • Kernel: x86_64 Linux 3.18.19-1-MANJARO
« Reply #11 on: 02. March 2016, 14:18:51 »
@Fab_  What problems are you getting?  I've created many bootable USB from ISO using dd each time and almost always worked.  The only time it didn't I checked the MD5sum and found that it was incorrect  :-[
Did you check this first?
"Whenever you find yourself on the side of the majority, it's time to pause and reflect."
-Mark Twain
