upgrade thunderbird 115.9.0-1 => 115.10.0-1 went wrong. unable to close the app. Aybody experiencing this also ?. Not only on manjaro … same thing on EOS.
downgrading to 115.9.0.1 made it work again.
sudo DOWNGRADE_FROM_ALA=1 downgrade thunderbird
inxi
Kernel: 6.1.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
root=UUID=b1a76660-f3e0-45ec-a0ec-c0c1d73738f5 rw rootflags=subvol=@
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: avail: xfce4-screensaver vt: 7 dm: LightDM
v: 1.32.0 Distro: Manjaro base: Arch Linux
Mobo: ASUSTeK model: ROG STRIX B560-F GAMING WIFI v: Rev 1.xx
UEFI: American Megatrends v: 1017 date: 07/12/2021
System RAM: total: 32 GiB available: 31.12 GiB used: 7.16 GiB (23.0%)
Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
Device-1: Controller0-ChannelA-DIMM0 type: no module installed
Device-2: Controller0-ChannelA-DIMM1 type: DDR4 detail: synchronous
size: 16 GiB speed: spec: 2133 MT/s actual: 3600 MT/s volts: note: check
curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Corsair part-no: CMK32GX4M2D3600C18 serial: N/A
Device-3: Controller0-ChannelB-DIMM0 type: no module installed
Device-4: Controller0-ChannelB-DIMM1 type: DDR4 detail: synchronous
Info: model: 11th Gen Intel Core i7-11700K bits: 64 type: MT MCP
arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x5D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 800 min/max: 800/4900:5000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800
bogomips: 115232
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm
fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdpid rdrand rdseed rdtscp rep_good sdbg sep sha_ni smap smep smx ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Type: retbleed mitigation: Enhanced IBRS
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
loop
Device-1: Intel RocketLake-S GT1 [UHD Graphics 750] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: HDMI-A-1 empty: DP-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:4c8a class-ID: 0300
Display: x11 server: X.org v: 1.21.1.12 compositor: xfwm4 v: 4.18.0
driver: X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
Monitor-1: HDMI-A-1 model: Idek Iiyama PLE2472HD serial: <filter>
built: 2010 res: 1920x1080 dpi: 92 gamma: 1.2 chroma: red: x: 0.639 y: 0.349
green: x: 0.333 y: 0.608 blue: x: 0.149 y: 0.055 white: x: 0.314 y: 0.329
size: 531x299mm (20.91x11.77") diag: 609mm (24") ratio: 16:9
modes: 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1280x960, 1152x864,
1024x768, 832x624, 800x600, 640x480, 720x400
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RKL GT1)
device-ID: 8086:4c8a memory: 30.39 GiB unified: yes
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:43c8 class-ID: 0403
API: ALSA v: k6.1.85-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0
chip-ID: 8086:15f3 class-ID: 0200
Info: services: mld, NetworkManager, sshd, systemd-timesyncd
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:8 chip-ID: 8087:0026
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: N/A rfk-block:
hardware: no software: no address: see --recommends
Local Storage: total: 7.28 TiB used: 4.02 TiB (55.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QGXA7 temp: 29.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QGXA7 temp: 28.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD60EFAX-68JH4N1 size: 5.46 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 0A83 scheme: GPT
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 21.77 GiB (21.8%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: b1a76660-f3e0-45ec-a0ec-c0c1d73738f5
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: BA25-82A9
ID-3: /data raw-size: 830.51 GiB size: 830.51 GiB (100.00%)
used: 276.07 GiB (33.2%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
label: N/A uuid: 03f93edd-164a-4996-b539-1c6492916736
ID-4: /home raw-size: 100 GiB size: 100 GiB (100.00%)
used: 21.77 GiB (21.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: b1a76660-f3e0-45ec-a0ec-c0c1d73738f5
ID-5: /storage raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 567.91 GiB (61.0%) fs: btrfs dev: /dev/nvme1n1p1 maj-min: 259:5
label: N/A uuid: f5595500-d6b5-428a-a9dc-4114a2692e4c
ID-6: /var/cache raw-size: 100 GiB size: 100 GiB (100.00%)
ID-7: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
ID-8: /wd6tb raw-size: 5.46 TiB size: 5.46 TiB (100.00%)
used: 3.17 TiB (58.1%) fs: btrfs dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: cc4d8185-6f7c-4009-8574-ef2f3f65aa10
ID-1: swap-1 type: zram size: 4 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 16 dev: /dev/zram0
Hub-2: 1-6:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
chip-ID: 174c:2074 class-ID: 0900
Device-1: 1-6.4:4 info: Razer USA RZ01-0321 Gaming Mouse [DeathAdder V2]
type: mouse,keyboard driver: hid-generic,usbhid interfaces: 4 rev: 2.0
chip-ID: 1532:0084 class-ID: 0300
Hub-3: 1-9:3 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
Device-1: 1-9.4:7 info: Metadot Das Keyboard 6 Pro type: keyboard,mouse
lanes: 1 mode: 1.1 power: 500mA chip-ID: 24f0:20a1 class-ID: 0301
Hub-4: 1-10:5 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-11:6 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
serial: <filter>
Device-2: 1-14:8 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-5: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
Hub-6: 2-5:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
chip-ID: 174c:3074 class-ID: 0900
System Temperatures: cpu: 28.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1074 libs: 336 tools: pamac,yay
1: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
2: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
3: https://mirror.koddos.net/manjaro/stable/$repo/$arch
4: https://manjaro.kurdy.org/stable/$repo/$arch
5: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
6: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
7: https://mirror.erickochen.nl/manjaro/stable/$repo/$arch
8: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
9: https://mirror.23m.com/manjaro/stable/$repo/$arch
10: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
11: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
12: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
13: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 397
1: cpu: 52.8% command: VirtualBoxVM pid: 1939 mem: 3389.4 MiB (10.6%)
2: cpu: 8.1% command: VirtualBoxVM pid: 1784 mem: 1049.9 MiB (3.2%)
3: cpu: 4.9% command: Xorg pid: 964 mem: 107.9 MiB (0.3%)
4: cpu: 1.7% command: xfce4-terminal pid: 2223 mem: 49.1 MiB (0.1%)
5: cpu: 1.0% command: xfwm4 pid: 1173 mem: 84.9 MiB (0.2%)
Memory top: 5 of 397
1: mem: 3389.4 MiB (10.6%) command: VirtualBoxVM pid: 1939 cpu: 52.8%
2: mem: 1049.9 MiB (3.2%) command: VirtualBoxVM pid: 1784 cpu: 8.1%
3: mem: 233.6 MiB (0.7%) command: VirtualBox pid: 1717 cpu: 0.6%
4: mem: 107.9 MiB (0.3%) command: Xorg pid: 964 cpu: 4.9%
5: mem: 84.9 MiB (0.2%) command: xfwm4 pid: 1173 cpu: 1.0%
Processes: 397 Power: uptime: 17m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.44 GiB
services: upowerd,xfce4-power-manager Init: systemd v: 255
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.26
running-in: xfce4-terminal inxi: 3.3.34
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
