[ARM Testing Update] 2021-07-13 - Firefox 90, MyGNUHealth, SystemD, Gnome 40.3 and kernels
Hello ARM community.
Lots of stuff in todays update.
Some highlights:
  • A couple of our kernels got updated
  • FIrefox got updated to it’s new major release 90.0
  • KDE Applications/Gear got updated to 21.04.3
  • Added MyGNUHealth to the repository
  • Gnome got a new point release with 40.3
  • Also SystemD got updated to version 249.3
  • Lots of Mobile specific packages got updated
  • Many python packages got updated
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
https://archlinux.org/news/sorting-out-old-password-hashes/
Older notifications
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
https://www.archlinux.org/news/ghostpcl9532-2-and-ghostxps9532-2-updates-require-manual-intervention/
The nss package requires manual intervention:
https://www.archlinux.org/news/nss3511-1-and-lib32-nss3511-1-updates-require-manual-intervention/
The packages hplip and firewalld requires manual intervention:
https://www.archlinux.org/news/hplip-3203-2-update-requires-manual-intervention/
https://www.archlinux.org/news/firewalld081-2-update-requires-manual-intervention/
Package Changes
(Tue Jul 13 20:30:30 CEST 2021)
  • arm-testing community aarch64: 225 new and 213 removed package(s)
  • arm-testing core aarch64: 34 new and 34 removed package(s)
  • arm-testing extra aarch64: 491 new and 490 removed package(s)
  • arm-testing kde-unstable aarch64: 381 new and 381 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE          2021-07-07         2021-07-13
                           bitwarden             1.27.0-1             1.27.1-1
                 breath2-icon-themes             1.0.11-2             1.0.14-1
                   breath2-wallpaper             1.0.11-2             1.0.14-1
                               calls  0.3.4+31+g9f45e8b-1  0.3.4+33+g27edac3-1
                                inxi           3.3.04.1-1           3.3.05.1-1
                    matcha-gtk-theme           20210624-1           20210708-1
                              matray              1.0.1-4              1.0.2-1
                                phoc              0.7.1-1  0.7.1+13+g527689d-1
                     pico-wizard-git       r127.5d96870-1       r142.0db2fdb-1
           pico-wizard-plamo-scripts       r127.5d96870-1       r142.0db2fdb-1
            pinebookpro-post-install           20210125-1           20210709-2
              plasma5-themes-breath2             1.0.11-2             1.0.14-1
                rockpi4-post-install           20210125-1           20210709-1
              rockpro64-post-install           20210125-1           20210709-2
                          rpi-eeprom           20210504-1           20210707-1
                  sddm-breath2-theme             1.0.11-2             1.0.14-1
                                 yay             10.2.3-2             10.3.0-1
                         mygnuhealth                    -              1.0.1-1
       plasma5-themes-breath2-shells                    -             1.0.14-1
                       python-tinydb                    -              4.5.0-1
:: Different sync package(s) in repository community aarch64
                                 afl              2.57b-6              2.57b-7
                   archlinux-contrib           20210418-1           20210710-1
                             aws-cli            1.19.93-1           1.19.107-1
                           babel-cli             7.14.5-1             7.14.5-2
                           bctoolbox             4.5.22-1              5.0.0-1
                                 bpf               5.12-1               5.13-1
                               bzrtp             4.5.22-1              5.0.0-1
                             calibre             5.22.1-1             5.23.0-1
                             cargo-c              0.8.2-1              0.9.1-1
                    cargo-spellcheck              0.8.6-1              0.8.8-1
                              catch2             2.13.3-1             2.13.6-1
                                ccls         0.20210330-2         0.20210330-3
                             certbot             1.16.0-1             1.17.0-1
                      certbot-apache             1.16.0-1             1.17.0-1
              certbot-dns-cloudflare             1.16.0-1             1.17.0-1
                certbot-dns-cloudxns             1.16.0-1             1.17.0-1
            certbot-dns-digitalocean             1.16.0-1             1.17.0-1
                certbot-dns-dnsimple             1.16.0-1             1.17.0-1
             certbot-dns-dnsmadeeasy             1.16.0-1             1.17.0-1
                  certbot-dns-gehirn             1.16.0-1             1.17.0-1
                  certbot-dns-google             1.16.0-1             1.17.0-1
                  certbot-dns-linode             1.16.0-1             1.17.0-1
                  certbot-dns-luadns             1.16.0-1             1.17.0-1
                   certbot-dns-nsone             1.16.0-1             1.17.0-1
                     certbot-dns-ovh             1.16.0-1             1.17.0-1
                 certbot-dns-rfc2136             1.16.0-1             1.17.0-1
                 certbot-dns-route53             1.16.0-1             1.17.0-1
             certbot-dns-sakuracloud             1.16.0-1             1.17.0-1
                       certbot-nginx             1.16.0-1             1.17.0-1
               cgroup_event_listener               5.12-1               5.13-1
                             chezmoi              2.1.0-1              2.1.1-1
                   containers-common             0.40.1-2             0.41.0-2
                            cppcheck              2.4.1-2                2.5-1
                            cpupower               5.12-1               5.13-1
                                crun             0.20.1-1             0.20.1-2
                         dark-reader             4.9.33-1             4.9.34-1
          deepin-qt5platform-plugins             5.0.23-2             5.0.23-3
                               doctl             1.61.0-1             1.62.0-1
                             drumkv1             0.9.22-1             0.9.23-1
                           dtkcommon              5.5.3-1             5.5.17-1
                      efm-langserver             0.0.31-1             0.0.34-1
                         endless-sky             0.9.13-2             0.9.14-1
                endless-sky-high-dpi             0.9.13-2             0.9.14-1
                                entr                4.9-1                5.0-1
                 firefox-dark-reader             4.9.33-1             4.9.34-1
              firefox-tree-style-tab              3.8.5-1              3.8.7-1
               firefox-ublock-origin             1.36.0-1             1.36.2-1
                                fish              3.2.2-2              3.3.1-1
                              gio-qt             0.0.10-1             0.0.11-1
                             glances              3.1.7-1              3.2.0-1
                             gpg-tui              0.6.2-1              0.7.0-1
                               gpgit            1:1.4.1-1            1:1.5.0-1
                          gpio-utils               5.12-1               5.13-1
                              grails             4.0.10-1             4.0.11-1
                         grails-docs             4.0.10-1             4.0.11-1
                           gscan2pdf             2.12.1-2             2.12.2-1
                               gsoap            2.8.114-1            2.8.115-1
                             haproxy              2.4.1-1              2.4.2-1
                               hexyl              0.8.0-1              0.9.0-1
                              hotdoc             0.13.3-1             0.13.4-1
                                hugo             0.84.4-1             0.85.0-1
                              hyperv               5.12-1               5.13-1
                               icewm              2.5.0-2              2.6.0-1
                    iio-sensor-proxy                3.0-1                3.1-1
                           iio-utils               5.12-1               5.13-1
                            innernet              1.3.1-1              1.4.0-1
                          jconvolver              1.0.3-2              1.1.0-1
                jedi-language-server             0.33.1-1             0.34.1-1
                                 k9s            0.24.13-1            0.24.14-1
                                kbfs              5.6.1-2              5.7.1-2
                             keybase              5.6.1-2              5.7.1-2
                         keybase-gui              5.6.1-2              5.7.1-2
                                 ldc           2:1.26.0-3           2:1.26.0-4
                                 lfs              0.7.5-1              0.7.6-1
                          liblphobos           2:1.26.0-3           2:1.26.0-4
                             libvips             8.11.1-2             8.11.2-1
                             libvirt            1:7.3.0-1            1:7.5.0-1
             libvirt-storage-gluster            1:7.3.0-1            1:7.5.0-1
        libvirt-storage-iscsi-direct            1:7.3.0-1            1:7.5.0-1
                    linux-tools-meta               5.12-1               5.13-1
                           liquidctl              1.6.1-1              1.7.0-1
                              logcli              2.2.1-2              2.2.1-3
                                loki              2.2.1-2              2.2.1-3
                         loki-canary              2.2.1-2              2.2.1-3
                              lutris            0.5.8.3-2            0.5.8.4-1
                                 lxd               4.15-1               4.16-1
                                mako                1.5-1                1.6-1
                             mbedtls             2.25.0-1             2.26.0-1
                       mediastreamer             4.5.22-1              5.0.0-1
                             mellite              3.5.7-1              3.6.0-1
                            minikube             1.21.0-1             1.22.0-1
                               minio         2021.06.09-1         2021.07.08-1
                              mopidy              3.1.1-3              3.2.0-1
                                mypy              0.910-1              0.910-2
             nextcloud-app-bookmarks            1:4.2.2-1            1:4.2.2-2
              nextcloud-app-calendar            1:2.3.0-1            1:2.3.0-3
              nextcloud-app-contacts              3.5.1-1              4.0.0-3
                  nextcloud-app-deck            1:1.4.2-1            1:1.4.2-2
                  nextcloud-app-mail              1.9.5-1              1.9.5-2
                 nextcloud-app-notes              4.0.4-1              4.1.0-3
                 nextcloud-app-tasks             0.13.6-1             0.13.6-2
                    nextcloud-client              3.2.3-1              3.2.4-1
     nextcloud-client-cloudproviders              3.2.3-1              3.2.4-1
                   npm-check-updates             11.8.0-1             11.8.2-1
                            nvme-cli               1.14-1               1.14-2
                      openfpgaloader              0.3.0-1              0.4.0-1
                         openvswitch             2.14.2-1             2.15.1-1
                                ortp             4.5.22-1              5.0.0-1
                              oxipng              4.0.3-1              5.0.0-1
                             padthv1             0.9.22-1             0.9.23-1
                                perf               5.12-1               5.13-1
                            plantuml           1.2021.6-1           1.2021.8-1
                              podman              3.2.2-1              3.2.2-2
                      podman-dnsname              1.2.0-1              1.2.0-2
                       podman-docker              3.2.2-1              3.2.2-2
                            promtail              2.2.1-2              2.2.1-3
                             pyright            1.1.155-1            1.1.156-1
                  python-aiobotocore              1.3.1-1              1.3.2-1
                      python-aiogram               2.14-1             2.14.2-1
                      python-apispec              4.7.0-1              4.7.1-1
           python-aws-sam-translator             1.36.0-1             1.37.0-1
                        python-boto3            1.17.93-1           1.17.107-1
                     python-botocore            1.20.93-1           1.20.107-1
            python-click-help-colors                0.9-1              0.9.1-1
                    python-cx-freeze                6.6-1                6.7-1
                        python-faker              8.9.1-1             8.10.0-1
                      python-fastapi             0.65.2-1             0.66.0-1
                  python-flask-dance              3.3.1-1              5.0.0-1
                        python-geopy              2.1.0-1              2.2.0-1
                        python-gmpy2            2.1.0b5-3            2.1.0b6-1
                          python-hid              1.0.4-3              1.0.4-4
                   python-hypothesis             6.14.1-1             6.14.2-1
                     python-identify             2.2.10-1             2.2.11-1
           python-importlib-metadata              4.5.0-1              4.6.0-1
            python-jupyterlab_server              2.6.0-1              2.6.1-1
                         python-kivy              2.0.0-1              2.0.0-2
                      python-libusb1              1.9.2-1              1.9.3-1
                  python-marshmallow             3.12.1-1             3.12.2-1
                     python-micawber              0.5.3-1              0.5.4-1
                         python-moto             2.0.10-1             2.0.11-1
                         python-nltk              3.6.2-1              3.6.2-4
                   python-oslo-utils              4.9.1-1              4.9.2-1
                 python-phonenumbers            8.12.26-1            8.12.27-1
                      python-pikepdf             2.14.0-1             2.14.2-1
                      python-pkginfo              1.7.0-1              1.7.1-1
                     python-pwntools              4.5.1-1              4.6.0-1
                      python-pymupdf            1.18.14-2            1.18.15-1
                        python-pyusb              1.1.1-1              1.2.1-1
                  python-pyvhdlmodel             0.10.2-1             0.11.1-1
                    python-reportlab             3.5.68-1             3.5.68-2
                         python-rich             10.5.0-1             10.6.0-1
             python-ruamel.yaml.clib              0.2.2-3              0.2.4-1
                   python-simplejson             3.17.2-4             3.17.3-1
                       python-sphinx              4.0.3-1              4.1.0-1
                         python-tqdm             4.61.1-1             4.61.2-1
                         python-zipp              3.4.1-1              3.5.0-1
               python-zita-jacktools              1.5.0-1              1.5.2-1
               python-zope-component              4.6.2-3              5.0.1-1
                            qtractor             0.9.22-1             0.9.23-1
                             remmina           1:1.4.19-1           1:1.4.20-1
                                repo               2.15-1               2.16-1
                        ruby-bundler             2.2.21-1             2.2.23-1
                           ruby-json              2.5.1-2              2.5.1-3
                         ruby-rugged              1.1.0-2              1.1.1-1
                         ruby-tzinfo              2.0.3-2              2.0.4-1
                             ruby2.6              2.6.7-1              2.6.8-1
                                runc              1.0.0-1              1.0.0-2
                       rust-analyzer           20210705-1           20210712-1
                             samplv1             0.9.22-1             0.9.23-1
                          serverless             2.50.0-1             2.51.1-1
                             shotcut           21.05.18-2           21.06.29-1
                            step-cli            0.15.16-1             0.16.1-1
                             synthv1             0.9.22-1             0.9.23-1
                               tanka             0.17.0-1             0.17.1-1
                             termite                 15-4                    -
                    termite-terminfo                 15-4                    -
                           terraform              1.0.1-1              1.0.2-1
             thunderbird-dark-reader             4.9.33-1             4.9.34-1
                               tiled              1.7.0-1              1.7.1-1
                         timescaledb              2.3.0-2              2.3.1-1
                                tmon               5.12-1               5.13-1
                             ts-node             10.0.0-1             10.1.0-1
                   ttf-sarasa-gothic             0.32.9-1            0.32.10-1
                         udisks2-qt5              5.0.5-1              5.0.6-1
                               usbip               5.12-1               5.13-1
                    uutils-coreutils              0.0.6-1              0.0.7-1
         v2ray-domain-list-community     20210702040554-1     20210711091359-1
                         v2ray-geoip       202107010026-1       202107080024-1
                           verilator              4.204-1              4.210-1
                           virtualgl              2.6.5-1              2.6.5-2
                           vultr-cli              2.5.3-1              2.6.0-2
                                wake             0.20.2-1             0.21.0-1
                              wcslib                7.6-1                7.7-1
                             wlroots             0.14.0-1             0.14.1-1
                             you-get           0.4.1527-1           0.4.1536-1
                     yubikey-manager              4.0.3-1              4.0.3-2
                                 cue                    -              0.4.0-1
                      deepin-wayland                    -              1.0.0-1
                   flatpak-xdg-utils                    -              1.0.4-4
                                mdk4                    -                4.2-1
                              pulumi                    -              3.6.1-2
                     python-aafigure                    -                0.6-1
                        python-oscpy                    -              0.6.0-1
                   python-pytest-env                    -              0.6.2-2
                            sqlx-cli                    -              0.5.5-2
                           ttf-input                    -           20191031-3
                             wmfocus                    -              1.2.0-1
:: Different overlay package(s) in repository core aarch64
                               linux             5.13.0-2             5.13.1-2
                       linux-headers             5.13.0-2             5.13.1-2
                     linux-pinephone            5.12.13-1            5.12.16-1
             linux-pinephone-headers            5.12.13-1            5.12.16-1
                      linux-quartz64           5.13.0-0.6           5.13.0-0.8
              linux-quartz64-headers           5.13.0-0.6           5.13.0-0.8
                            linux-rc           5.13.rc7-1           5.14.rc1-3
                    linux-rc-headers           5.13.rc7-1           5.14.rc1-3
                          linux-rpi4            5.10.46-1            5.10.48-1
                  linux-rpi4-headers            5.10.46-1            5.10.48-1
                 linux-rpi4-mainline            5.12.10-1            5.12.15-1
         linux-rpi4-mainline-headers            5.12.10-1            5.12.15-1
              raspberrypi-bootloader           20210628-1           20210709-1
            raspberrypi-bootloader-x           20210628-1           20210709-1
                     uboot-nanopc-t4            2021.04-1            2021.07-1
            uboot-odroid-c2-mainline            2021.04-2            2021.07-1
                      uboot-pine-h64            2021.04-1            2021.07-1
                        uboot-pine64            2021.04-1            2021.07-1
                    uboot-pine64-lts            2021.04-1            2021.07-1
                      uboot-pinebook            2021.04-1            2021.07-1
                   uboot-pinebookpro            2021.04-3            2021.07-1
                     uboot-pinephone            2021.04-1            2021.07-1
                       uboot-pinetab            2021.04-1            2021.07-1
                   uboot-raspberrypi            2021.04-2            2021.07-2
                        uboot-roc-cc            2021.04-1            2021.07-1
                        uboot-rock64            2021.04-1            2021.07-1
                      uboot-rockpi4b            2021.04-1            2021.07-1
                      uboot-rockpi4c            2021.04-1            2021.07-1
                     uboot-rockpro64            2021.04-1            2021.07-1
:: Different sync package(s) in repository core aarch64
                              libcap               2.50-2               2.51-1
                             systemd              248.3-2                249-3
                        systemd-libs              248.3-2                249-3
                  systemd-resolvconf              248.3-2                249-3
                  systemd-sysvcompat              248.3-2                249-3
:: Different overlay package(s) in repository extra aarch64
                       calamares-qml             3.2.40-0           3.2.40-0.1
                             firefox             89.0.2-1               90.0-1
                    firefox-i18n-ach             89.0.2-1               90.0-1
                     firefox-i18n-af             89.0.2-1               90.0-1
                     firefox-i18n-an             89.0.2-1               90.0-1
                     firefox-i18n-ar             89.0.2-1               90.0-1
                    firefox-i18n-ast             89.0.2-1               90.0-1
                     firefox-i18n-az             89.0.2-1               90.0-1
                     firefox-i18n-be             89.0.2-1               90.0-1
                     firefox-i18n-bg             89.0.2-1               90.0-1
                     firefox-i18n-bn             89.0.2-1               90.0-1
                     firefox-i18n-br             89.0.2-1               90.0-1
                     firefox-i18n-bs             89.0.2-1               90.0-1
                     firefox-i18n-ca             89.0.2-1               90.0-1
                    firefox-i18n-cak             89.0.2-1               90.0-1
                     firefox-i18n-cs             89.0.2-1               90.0-1
                     firefox-i18n-cy             89.0.2-1               90.0-1
                     firefox-i18n-da             89.0.2-1               90.0-1
                     firefox-i18n-de             89.0.2-1               90.0-1
                    firefox-i18n-dsb             89.0.2-1               90.0-1
                     firefox-i18n-el             89.0.2-1               90.0-1
                  firefox-i18n-en-ca             89.0.2-1               90.0-1
                  firefox-i18n-en-gb             89.0.2-1               90.0-1
                  firefox-i18n-en-us             89.0.2-1               90.0-1
                     firefox-i18n-eo             89.0.2-1               90.0-1
                  firefox-i18n-es-ar             89.0.2-1               90.0-1
                  firefox-i18n-es-cl             89.0.2-1               90.0-1
                  firefox-i18n-es-es             89.0.2-1               90.0-1
                  firefox-i18n-es-mx             89.0.2-1               90.0-1
                     firefox-i18n-et             89.0.2-1               90.0-1
                     firefox-i18n-eu             89.0.2-1               90.0-1
                     firefox-i18n-fa             89.0.2-1               90.0-1
                     firefox-i18n-ff             89.0.2-1               90.0-1
                     firefox-i18n-fi             89.0.2-1               90.0-1
                     firefox-i18n-fr             89.0.2-1               90.0-1
                  firefox-i18n-fy-nl             89.0.2-1               90.0-1
                  firefox-i18n-ga-ie             89.0.2-1               90.0-1
                     firefox-i18n-gd             89.0.2-1               90.0-1
                     firefox-i18n-gl             89.0.2-1               90.0-1
                     firefox-i18n-gn             89.0.2-1               90.0-1
                  firefox-i18n-gu-in             89.0.2-1               90.0-1
                     firefox-i18n-he             89.0.2-1               90.0-1
                  firefox-i18n-hi-in             89.0.2-1               90.0-1
                     firefox-i18n-hr             89.0.2-1               90.0-1
                    firefox-i18n-hsb             89.0.2-1               90.0-1
                     firefox-i18n-hu             89.0.2-1               90.0-1
                  firefox-i18n-hy-am             89.0.2-1               90.0-1
                     firefox-i18n-ia             89.0.2-1               90.0-1
                     firefox-i18n-id             89.0.2-1               90.0-1
                     firefox-i18n-is             89.0.2-1               90.0-1
                     firefox-i18n-it             89.0.2-1               90.0-1
                     firefox-i18n-ja             89.0.2-1               90.0-1
                     firefox-i18n-ka             89.0.2-1               90.0-1
                    firefox-i18n-kab             89.0.2-1               90.0-1
                     firefox-i18n-kk             89.0.2-1               90.0-1
                     firefox-i18n-km             89.0.2-1               90.0-1
                     firefox-i18n-kn             89.0.2-1               90.0-1
                     firefox-i18n-ko             89.0.2-1               90.0-1
                    firefox-i18n-lij             89.0.2-1               90.0-1
                     firefox-i18n-lt             89.0.2-1               90.0-1
                     firefox-i18n-lv             89.0.2-1               90.0-1
                     firefox-i18n-mk             89.0.2-1               90.0-1
                     firefox-i18n-mr             89.0.2-1               90.0-1
                     firefox-i18n-ms             89.0.2-1               90.0-1
                     firefox-i18n-my             89.0.2-1               90.0-1
                  firefox-i18n-nb-no             89.0.2-1               90.0-1
                  firefox-i18n-ne-np             89.0.2-1               90.0-1
                     firefox-i18n-nl             89.0.2-1               90.0-1
                  firefox-i18n-nn-no             89.0.2-1               90.0-1
                     firefox-i18n-oc             89.0.2-1               90.0-1
                  firefox-i18n-pa-in             89.0.2-1               90.0-1
                     firefox-i18n-pl             89.0.2-1               90.0-1
                  firefox-i18n-pt-br             89.0.2-1               90.0-1
                  firefox-i18n-pt-pt             89.0.2-1               90.0-1
                     firefox-i18n-rm             89.0.2-1               90.0-1
                     firefox-i18n-ro             89.0.2-1               90.0-1
                     firefox-i18n-ru             89.0.2-1               90.0-1
                     firefox-i18n-si             89.0.2-1               90.0-1
                     firefox-i18n-sk             89.0.2-1               90.0-1
                     firefox-i18n-sl             89.0.2-1               90.0-1
                    firefox-i18n-son             89.0.2-1               90.0-1
                     firefox-i18n-sq             89.0.2-1               90.0-1
                     firefox-i18n-sr             89.0.2-1               90.0-1
                  firefox-i18n-sv-se             89.0.2-1               90.0-1
                     firefox-i18n-ta             89.0.2-1               90.0-1
                     firefox-i18n-te             89.0.2-1               90.0-1
                     firefox-i18n-th             89.0.2-1               90.0-1
                     firefox-i18n-tr             89.0.2-1               90.0-1
                     firefox-i18n-uk             89.0.2-1               90.0-1
                     firefox-i18n-ur             89.0.2-1               90.0-1
                     firefox-i18n-uz             89.0.2-1               90.0-1
                     firefox-i18n-vi             89.0.2-1               90.0-1
                     firefox-i18n-xh             89.0.2-1               90.0-1
                  firefox-i18n-zh-cn             89.0.2-1               90.0-1
                  firefox-i18n-zh-tw             89.0.2-1               90.0-1
                            mesa-git21.2.0_devel.141996.c246af0dd80-121.2.0_devel.142376.c70f45c7596-1
                        qt5-es2-base    5.15.2+kde+r203-1    5.15.2+kde+r207-1
         qt5-es2-xcb-private-headers    5.15.2+kde+r200-1    5.15.2+kde+r207-1
               calamares-arm-oem-qml                    -           20210708-1
:: Different sync package(s) in repository extra aarch64
                             akonadi            21.04.2-1            21.04.3-1
                    akonadi-calendar            21.04.2-1            21.04.3-1
              akonadi-calendar-tools            21.04.2-1            21.04.3-1
                    akonadi-contacts            21.04.2-1            21.04.3-1
               akonadi-import-wizard            21.04.2-1            21.04.3-1
                        akonadi-mime            21.04.2-1            21.04.3-1
                       akonadi-notes            21.04.2-1            21.04.3-1
                      akonadi-search            21.04.2-1            21.04.3-1
                      akonadiconsole            21.04.2-1            21.04.3-1
                           akregator            21.04.2-1            21.04.3-1
                            analitza            21.04.2-1            21.04.3-1
                                 ark            21.04.2-1            21.04.3-1
                          artikulate            21.04.2-1            21.04.3-1
                        at-spi2-core             2.40.2-1             2.40.3-1
                              attica             5.83.0-1             5.84.0-1
                         audiocd-kio            21.04.2-1            21.04.3-1
                               baloo             5.83.0-1             5.84.0-1
                       baloo-widgets            21.04.2-1            21.04.3-1
                             blinken            21.04.2-1            21.04.3-1
                               bluez               5.59-2               5.60-1
                          bluez-cups               5.59-2               5.60-1
                       bluez-hid2hci               5.59-2               5.60-1
                          bluez-libs               5.59-2               5.60-1
                       bluez-plugins               5.59-2               5.60-1
                            bluez-qt             5.83.0-1             5.84.0-1
                         bluez-utils               5.59-2               5.60-1
                              bomber            21.04.2-1            21.04.3-1
                                bovo            21.04.2-1            21.04.3-1
                        breeze-icons             5.83.0-1             5.84.0-1
                     calendarsupport            21.04.2-1            21.04.3-1
                              cantor            21.04.2-1            21.04.3-1
                            cervisia            21.04.2-1            21.04.3-1
                               clang             12.0.0-1             12.0.1-1
                          claws-mail             3.17.8-2             3.18.0-1
                         compiler-rt             12.0.0-1             12.0.1-2
                             digikam              7.2.0-5              7.3.0-2
                             dolphin            21.04.2-1            21.04.3-1
                     dolphin-plugins            21.04.2-1            21.04.3-1
                              dragon            21.04.2-1            21.04.3-1
                               elisa            21.04.2-1            21.04.3-1
                          eventviews            21.04.2-1            21.04.3-1
                           evolution             3.40.2-1             3.40.3-1
                evolution-bogofilter             3.40.2-1             3.40.3-1
               evolution-data-server             3.40.2-2             3.40.3-1
                       evolution-ews             3.40.2-1             3.40.3-1
              evolution-spamassassin             3.40.2-1             3.40.3-1
                 extra-cmake-modules             5.83.0-1             5.84.0-1
                        ffmpegthumbs            21.04.2-1            21.04.3-1
                           filelight            21.04.2-1            21.04.3-1
                               finch             2.14.5-1             2.14.6-1
                frameworkintegration             5.83.0-1             5.84.0-1
                                  gn    0.1897.dba01723-1    0.1910.39a87c0b-1
                    gnome-devel-docs               40.0-1               40.3-1
                  gnome-disk-utility               40.1-2               40.2-1
                          gnome-maps               40.2-1               40.3-1
                         gnome-shell             1:40.2-1             1:40.3-1
              gnome-shell-extensions               40.2-1               40.3-1
                      gnome-software               40.2-1               40.3-1
    gnome-software-packagekit-plugin               40.2-1               40.3-1
                      gnome-terminal             3.40.2-1             3.40.3-1
                     gnome-user-docs               40.1-1               40.3-1
                           granatier            21.04.2-1            21.04.3-1
                     grantlee-editor            21.04.2-1            21.04.3-1
                       grantleetheme            21.04.2-1            21.04.3-1
                     grml-zsh-config             0.18.0-1             0.19.0-1
                                gtk3          1:3.24.29-2          1:3.24.30-1
                          gtk3-demos          1:3.24.29-2          1:3.24.30-1
                           gtk3-docs          1:3.24.29-2          1:3.24.30-1
                           gucharmap             13.0.6-1             13.0.8-1
                            gwenview            21.04.2-1            21.04.3-1
                            harfbuzz              2.8.1-1              2.8.2-1
                        harfbuzz-icu              2.8.1-1              2.8.2-1
                     incidenceeditor            21.04.2-1            21.04.3-1
                           itinerary            21.04.2-1            21.04.3-1
                                 juk            21.04.2-1            21.04.3-1
                                 k3b          1:21.04.2-1          1:21.04.3-1
               kaccounts-integration            21.04.2-1            21.04.3-1
                 kaccounts-providers            21.04.2-1            21.04.3-1
                         kactivities             5.83.0-1             5.84.0-1
                   kactivities-stats             5.83.0-1             5.84.0-1
                        kaddressbook            21.04.2-1            21.04.3-1
                             kajongg            21.04.2-1            21.04.3-1
                              kalarm            21.04.2-1            21.04.3-1
                           kalarmcal            21.04.2-1            21.04.3-1
                            kalgebra            21.04.2-1            21.04.3-1
                             kalzium            21.04.2-1            21.04.3-1
                              kamera            21.04.2-1            21.04.3-1
                              kamoso            21.04.2-1            21.04.3-1
                            kanagram            21.04.2-1            21.04.3-1
                             kapidox             5.83.0-1             5.84.0-1
                              kapman            21.04.2-1            21.04.3-1
                        kapptemplate            21.04.2-1            21.04.3-1
                            karchive             5.83.0-1             5.84.0-1
                                kate            21.04.2-1            21.04.3-1
                             katomic            21.04.2-1            21.04.3-1
                               kauth             5.83.0-1             5.84.0-1
                             kbackup            21.04.2-1            21.04.3-1
                           kblackbox            21.04.2-1            21.04.3-1
                             kblocks            21.04.2-1            21.04.3-1
                          kbookmarks             5.83.0-1             5.84.0-1
                             kbounce            21.04.2-1            21.04.3-1
                           kbreakout            21.04.2-1            21.04.3-1
                              kbruch            21.04.2-1            21.04.3-1
                         kcachegrind            21.04.2-1            21.04.3-1
                  kcachegrind-common            21.04.2-1            21.04.3-1
                               kcalc            21.04.2-1            21.04.3-1
                       kcalendarcore             5.83.0-1             5.84.0-1
                           kcalutils            21.04.2-1            21.04.3-1
                         kcharselect            21.04.2-1            21.04.3-1
                            kcmutils             5.83.0-1             5.84.0-1
                             kcodecs             5.83.0-1             5.84.0-1
                       kcolorchooser            21.04.2-1            21.04.3-1
                         kcompletion             5.83.0-1             5.84.0-1
                             kconfig             5.83.0-1             5.84.0-1
                      kconfigwidgets             5.83.0-1             5.84.0-1
                           kcontacts           1:5.83.0-1           1:5.84.0-1
                         kcoreaddons             5.83.0-1             5.84.0-1
                              kcrash             5.83.0-1             5.84.0-1
                               kcron            21.04.2-1            21.04.3-1
                                kdav           1:5.83.0-1           1:5.84.0-1
                         kdbusaddons             5.83.0-1             5.84.0-1
                     kde-dev-scripts            21.04.2-1            21.04.3-1
                       kde-dev-utils            21.04.2-1            21.04.3-1
                      kdebugsettings            21.04.2-1            21.04.3-1
                        kdeclarative             5.83.0-1             5.84.0-1
                          kdeconnect            21.04.2-1            21.04.3-1
                                kded             5.83.0-1             5.84.0-1
                         kdeedu-data            21.04.2-1            21.04.3-1
              kdegraphics-mobipocket            21.04.2-1            21.04.3-1
            kdegraphics-thumbnailers            21.04.2-1            21.04.3-1
                     kdelibs4support             5.83.0-1             5.84.0-1
              kdenetwork-filesharing            21.04.2-1            21.04.3-1
                            kdenlive            21.04.2-2            21.04.3-1
                       kdepim-addons            21.04.2-1            21.04.3-1
                      kdepim-runtime            21.04.2-1            21.04.3-1
                    kdesdk-kioslaves            21.04.2-1            21.04.3-1
                 kdesdk-thumbnailers            21.04.2-1            21.04.3-1
                     kdesignerplugin             5.83.0-1             5.84.0-1
                               kdesu             5.83.0-1             5.84.0-1
                            kdevelop              5.6.2-4              5.6.2-5
                           kdewebkit             5.83.0-1             5.84.0-1
                                 kdf            21.04.2-1            21.04.3-1
                             kdialog            21.04.2-1            21.04.3-1
                            kdiamond            21.04.2-1            21.04.3-1
                              kdnssd             5.83.0-1             5.84.0-1
                           kdoctools             5.83.0-1             5.84.0-1
                      keditbookmarks            21.04.2-1            21.04.3-1
                          kemoticons             5.83.0-1             5.84.0-1
                       kfilemetadata             5.83.0-1             5.84.0-1
                               kfind            21.04.2-1            21.04.3-1
                             kfloppy            21.04.2-1            21.04.3-1
                         kfourinline            21.04.2-1            21.04.3-1
                          kgeography            21.04.2-1            21.04.3-1
                                kget            21.04.2-1            21.04.3-1
                        kglobalaccel             5.83.0-1             5.84.0-1
                         kgoldrunner            21.04.2-1            21.04.3-1
                                kgpg            21.04.2-1            21.04.3-1
                          kguiaddons             5.83.0-1             5.84.0-1
                            khangman            21.04.2-1            21.04.3-1
                         khelpcenter            21.04.2-1            21.04.3-1
                           kholidays           1:5.83.0-1           1:5.84.0-1
                               khtml             5.83.0-1             5.84.0-1
                               ki18n             5.83.0-1             5.84.0-1
                         kiconthemes             5.83.0-1             5.84.0-1
                 kidentitymanagement            21.04.2-1            21.04.3-1
                           kidletime             5.83.0-1             5.84.0-1
                                 kig            21.04.2-1            21.04.3-1
                                kigo            21.04.2-1            21.04.3-1
                            killbots            21.04.2-1            21.04.3-1
                       kimageformats             5.83.0-4             5.84.0-1
                     kimagemapeditor            21.04.2-1            21.04.3-1
                               kimap            21.04.2-1            21.04.3-1
                               kinit             5.83.0-1             5.84.0-1
                                 kio             5.83.0-1             5.84.0-1
                          kio-extras            21.04.2-3            21.04.3-1
                          kio-gdrive            21.04.2-1            21.04.3-1
                        kipi-plugins            21.04.2-1            21.04.3-1
                    kirigami-gallery            21.04.2-1            21.04.3-1
                           kirigami2             5.83.0-1             5.84.0-1
                              kiriki            21.04.2-1            21.04.3-1
                         kitemmodels             5.83.0-1             5.84.0-1
                          kitemviews             5.83.0-1             5.84.0-1
                               kiten            21.04.2-1            21.04.3-1
                          kitinerary            21.04.2-2            21.04.3-1
                         kjobwidgets             5.83.0-1             5.84.0-1
                                 kjs             5.83.0-1             5.84.0-1
                            kjsembed             5.83.0-1             5.84.0-1
                        kjumpingcube            21.04.2-1            21.04.3-1
                               kldap            21.04.2-1            21.04.3-1
                           kleopatra            21.04.2-1            21.04.3-1
                            klettres            21.04.2-1            21.04.3-1
                            klickety            21.04.2-1            21.04.3-1
                              klines            21.04.2-1            21.04.3-1
                                kmag            21.04.2-1            21.04.3-1
                           kmahjongg            21.04.2-1            21.04.3-1
                               kmail            21.04.2-1            21.04.3-1
                kmail-account-wizard            21.04.2-1            21.04.3-1
                      kmailtransport            21.04.2-1            21.04.3-1
                               kmbox            21.04.2-1            21.04.3-1
                        kmediaplayer             5.83.0-1             5.84.0-1
                               kmime            21.04.2-1            21.04.3-1
                              kmines            21.04.2-1            21.04.3-1
                                kmix            21.04.2-1            21.04.3-1
                          kmousetool            21.04.2-1            21.04.3-1
                              kmouth            21.04.2-1            21.04.3-1
                              kmplot            21.04.2-1            21.04.3-1
                        knavalbattle            21.04.2-1            21.04.3-1
                            knetwalk            21.04.2-1            21.04.3-1
                           knewstuff             5.83.0-1             5.84.0-1
                             knights            21.04.2-1            21.04.3-1
                              knotes            21.04.2-1            21.04.3-1
                      knotifications             5.83.0-1             5.84.0-1
                       knotifyconfig             5.83.0-1             5.84.0-1
                                kolf            21.04.2-1            21.04.3-1
                           kollision            21.04.2-1            21.04.3-1
                         kolourpaint            21.04.2-1            21.04.3-1
                             kompare            21.04.2-1            21.04.3-1
                           konqueror            21.04.2-1            21.04.3-1
                            konquest            21.04.2-1            21.04.3-1
                             konsole            21.04.2-1            21.04.3-1
                             kontact            21.04.2-1            21.04.3-1
                    kontactinterface            21.04.2-1            21.04.3-1
                            kontrast            21.04.2-1            21.04.3-1
                        konversation            21.04.2-1            21.04.3-1
                       kopeninghours            21.04.2-1            21.04.3-1
                              kopete            21.04.2-1            21.04.3-1
                          korganizer            21.04.2-1            21.04.3-1
                       kosmindoormap            21.04.2-2            21.04.3-1
                            kpackage             5.83.0-1             5.84.0-1
                              kparts             5.83.0-1             5.84.0-1
                                kpat            21.04.2-1            21.04.3-1
                             kpeople             5.83.0-1             5.84.0-1
                        kpimtextedit            21.04.2-1            21.04.3-1
                             kpkpass            21.04.2-1            21.04.3-1
                           kplotting             5.83.0-1             5.84.0-1
                             kpmcore            21.04.2-1            21.04.3-1
                                kpty             5.83.0-1             5.84.0-1
                    kpublictransport            21.04.2-1            21.04.3-1
                      kqtquickcharts            21.04.2-1            21.04.3-1
                        kquickcharts             5.83.0-1             5.84.0-1
                                krdc            21.04.2-1            21.04.3-1
                            kreversi            21.04.2-1            21.04.3-1
                                krfb            21.04.2-1            21.04.3-1
                               kross             5.83.0-1             5.84.0-1
                  kross-interpreters            21.04.2-1            21.04.3-1
                              kruler            21.04.2-1            21.04.3-1
                             krunner             5.83.0-1             5.84.0-1
                            kservice             5.83.0-1             5.84.0-1
                             kshisen            21.04.2-1            21.04.3-1
                               ksirk            21.04.2-1            21.04.3-1
                               ksmtp            21.04.2-1            21.04.3-1
                          ksnakeduel            21.04.2-1            21.04.3-1
                          kspaceduel            21.04.2-1            21.04.3-1
                            ksquares            21.04.2-1            21.04.3-1
                             ksudoku            21.04.2-1            21.04.3-1
                          ksystemlog            21.04.2-1            21.04.3-1
                            kteatime            21.04.2-1            21.04.3-1
                         ktexteditor             5.83.0-1             5.84.0-1
                        ktextwidgets             5.83.0-1             5.84.0-1
                              ktimer            21.04.2-1            21.04.3-1
                               ktnef            21.04.2-1            21.04.3-1
                            ktorrent            21.04.2-1            21.04.3-1
                              ktouch            21.04.2-1            21.04.3-1
                          ktuberling            21.04.2-1            21.04.3-1
                             kturtle            21.04.2-1            21.04.3-1
                             kubrick            21.04.2-1            21.04.3-1
                     kunitconversion             5.83.0-1             5.84.0-1
                             kwallet             5.83.0-1             5.84.0-1
                      kwalletmanager            21.04.2-1            21.04.3-1
                               kwave            21.04.2-1            21.04.3-1
                            kwayland             5.83.0-1             5.84.0-1
                      kwidgetsaddons             5.83.0-1             5.84.0-1
                       kwindowsystem             5.83.0-1             5.84.0-1
                           kwordquiz            21.04.2-1            21.04.3-1
                              kwrite            21.04.2-1            21.04.3-1
                             kxmlgui             5.83.0-1             5.84.0-1
                       kxmlrpcclient             5.83.0-1             5.84.0-1
                          libakonadi            21.04.2-1            21.04.3-1
                              libclc             12.0.0-1             12.0.1-1
                         libgravatar            21.04.2-1            21.04.3-1
                            libkcddb            21.04.2-1            21.04.3-1
                     libkcompactdisc            21.04.2-1            21.04.3-1
                           libkdcraw            21.04.2-1            21.04.3-1
                         libkdegames            21.04.2-1            21.04.3-1
                           libkdepim            21.04.2-1            21.04.3-1
                  libkeduvocdocument            21.04.2-1            21.04.3-1
                           libkexiv2            21.04.2-1            21.04.3-1
                            libkgapi            21.04.2-1            21.04.3-1
                             libkipi            21.04.2-1            21.04.3-1
                             libkleo            21.04.2-1            21.04.3-1
                        libkmahjongg            21.04.2-1            21.04.3-1
                     libkomparediff2            21.04.2-1            21.04.3-1
                            libksane            21.04.2-1            21.04.3-1
                           libksieve            21.04.2-1            21.04.3-1
                         libktorrent            21.04.2-1            21.04.3-1
                           libpurple             2.14.5-1             2.14.6-1
                                 lld             12.0.0-1             12.0.1-1
                                lldb             12.0.0-1             12.0.1-1
                                llvm             12.0.0-2             12.0.1-1
                           llvm-libs             12.0.0-2             12.0.1-1
                          llvm-ocaml             12.0.0-2             12.0.1-1
                            lokalize            21.04.2-1            21.04.3-1
                               lskat            21.04.2-1            21.04.3-1
                          mailcommon            21.04.2-1            21.04.3-1
                        mailimporter            21.04.2-1            21.04.3-1
                              marble            21.04.2-2            21.04.3-1
                       marble-common            21.04.2-2            21.04.3-1
                         marble-maps            21.04.2-2            21.04.3-1
                           marble-qt            21.04.2-2            21.04.3-1
                        markdownpart            21.04.2-1            21.04.3-1
                       mbox-importer            21.04.2-1            21.04.3-1
                          messagelib            21.04.2-1            21.04.3-1
                              minuet            21.04.2-1            21.04.3-1
                     modemmanager-qt             5.83.0-1             5.84.0-1
                              mtools           1:4.0.31-1           1:4.0.32-1
                              mutter             40.2.1-1               40.3-1
                   networkmanager-qt             5.83.0-1             5.84.0-1
                              okular            21.04.2-1            21.04.3-1
                              openmp             12.0.0-1             12.0.1-1
                        oxygen-icons           1:5.83.0-1           1:5.84.0-1
                    oxygen-icons-svg           1:5.83.0-1           1:5.84.0-1
                            palapeli            21.04.2-1            21.04.3-1
                              parley            21.04.2-1            21.04.3-1
                    partitionmanager            21.04.2-1            21.04.3-1
                   perl-file-basedir               0.08-6               0.09-1
                               picmi            21.04.2-1            21.04.3-1
                              pidgin             2.14.5-1             2.14.6-1
                   pim-data-exporter            21.04.2-1            21.04.3-1
                    pim-sieve-editor            21.04.2-1            21.04.3-1
                           pimcommon            21.04.2-1            21.04.3-1
                    plasma-framework             5.83.0-1             5.84.0-1
                              polari               40.0-1               40.1-1
                               polly             12.0.0-1             12.0.1-1
                               poxml            21.04.2-1            21.04.3-1
                       print-manager            21.04.2-1            21.04.3-1
                              prison             5.83.0-1             5.84.0-1
                             purpose             5.83.0-1             5.84.0-1
                         python-cffi             1.14.5-1             1.14.6-1
                    python-shiboken2             5.15.2-8             5.15.2-9
                        python2-cffi             1.14.5-1             1.14.6-1
                         qcachegrind            21.04.2-1            21.04.3-1
                  qqc2-desktop-style             5.83.0-1             5.84.0-1
                            qt5-base    5.15.2+kde+r207-1    5.15.2+kde+r209-1
                           qt5-tools     5.15.2+kde+r17-2     5.15.2+kde+r17-3
             qt5-xcb-private-headers    5.15.2+kde+r207-1    5.15.2+kde+r209-1
                           qt6-tools              6.1.2-1              6.1.2-2
                           qtcreator             4.15.1-1             4.15.1-2
                                rocs            21.04.2-1            21.04.3-1
                                rust           1:1.53.0-1           1:1.53.0-2
                           rust-docs           1:1.53.0-1           1:1.53.0-2
                           shiboken6              6.1.2-1              6.1.2-2
            signon-kwallet-extension            21.04.2-1            21.04.3-1
                               solid             5.83.0-1             5.84.0-1
                              sonnet             5.83.0-1             5.84.0-1
                           spectacle            21.04.2-1            21.04.3-1
                                step            21.04.2-1            21.04.3-1
                             svgpart            21.04.2-1            21.04.3-1
                             sweeper            21.04.2-1            21.04.3-1
                         syndication             5.83.0-1             5.84.0-1
                 syntax-highlighting             5.83.0-1             5.84.0-1
                           syslog-ng             3.32.1-2             3.33.1-1
          telepathy-kde-accounts-kcm            21.04.2-1            21.04.3-1
              telepathy-kde-approver            21.04.2-1            21.04.3-1
          telepathy-kde-auth-handler            21.04.2-1            21.04.3-1
               telepathy-kde-call-ui            21.04.2-1            21.04.3-1
      telepathy-kde-common-internals            21.04.2-1            21.04.3-1
          telepathy-kde-contact-list            21.04.2-1            21.04.3-1
        telepathy-kde-contact-runner            21.04.2-1            21.04.3-1
       telepathy-kde-desktop-applets            21.04.2-1            21.04.3-1
  telepathy-kde-filetransfer-handler            21.04.2-1            21.04.3-1
    telepathy-kde-integration-module            21.04.2-1            21.04.3-1
             telepathy-kde-send-file            21.04.2-1            21.04.3-1
               telepathy-kde-text-ui            21.04.2-1            21.04.3-1
                        threadweaver             5.83.0-1             5.84.0-1
                            umbrello            21.04.2-1            21.04.3-1
                          webkit2gtk             2.32.1-1             2.32.2-1
                         xorg-server            1.20.11-1            1.20.12-1
                  xorg-server-common            1.20.11-1            1.20.12-1
                   xorg-server-devel            1.20.11-1            1.20.12-1
                  xorg-server-xephyr            1.20.11-1            1.20.12-1
                   xorg-server-xnest            1.20.11-1            1.20.12-1
                    xorg-server-xvfb            1.20.11-1            1.20.12-1
                       xorg-xwayland             21.1.1-1             21.1.2-1
                             yakuake            21.04.2-1            21.04.3-1
                                yelp               40.2-1               40.3-1
                        zabbix-agent              5.4.1-1              5.4.2-1
                       zabbix-agent2              5.4.1-1              5.4.2-1
                 zabbix-frontend-php              5.4.1-1              5.4.2-1
                        zabbix-proxy              5.4.1-1              5.4.2-1
                       zabbix-server              5.4.1-1              5.4.2-1
                    zeroconf-ioslave            21.04.2-1            21.04.3-1
:: Different overlay package(s) in repository kde-unstable aarch64
                             akonadi21.04.2.r12512.ge9f90a3b0-121.04.3.r12519.g0bc009687-1
                    akonadi-calendar21.04.2.r1944.gf896763-121.04.3.r1957.gc471bcd-1
              akonadi-calendar-tools21.04.2.r869.g7e8b4be-121.04.3.r876.g6b18da3-1
                    akonadi-contacts21.04.2.r3019.g3ebd8c70-121.04.3.r3025.gb91ab23d-1
               akonadi-import-wizard21.04.2.r1713.g868f978-121.04.3.r1720.gf4ac9fa-1
                        akonadi-mime21.04.2.r1623.g3edcb1b-121.04.3.r1629.ga655c95-1
                       akonadi-notes21.04.2.r1007.gf075b89-121.04.3.r1013.g3ddecb2-1
                      akonadi-search21.04.2.r1100.g19cde5a-121.04.3.r1106.g49c9837-1
                      akonadiconsole21.04.2.r1495.gbcbd584-121.04.3.r1501.g7eef7f3-1
                           akregator21.04.2.r6168.g0babd287-121.04.3.r6177.ga8a3a2ee-1
                           alligator  21.06.r3.g6494e0e-1  21.06.r6.ga92562e-1
                            amazfish 2.0.0.r22.g35d2960-1  2.0.1.r0.g34365e4-1
                            analitza21.04.2.r2330.g7072e346-121.04.3.r2330.g7072e346-1
                           angelfish 21.06.r10.g0861230-1 21.06.r13.gccfa889-1
                                 ark21.04.2.r4549.g179fb90e-121.04.3.r4593.g6f262cdd-1
                          artikulate21.04.2.r1385.g92aea80-121.04.3.r1388.g89c15b6-1
                              attica5.83.0.r820.g040d354-25.84.0.r822.ga90893d-1
                         audiocd-kio21.04.2.r1018.ge260225-121.04.3.r1023.g523fd27-1
                               baloo5.83.0.r2992.gfae7732d-25.83.0.r2993.g62c03736-1
                       baloo-widgets21.04.2.r679.g38ef1b5-121.04.3.r680.g5a3b20a-1
                             blinken21.04.2.r623.g07b1991-121.04.3.r627.g7ca2a7a-1
                           bluedevil1:5.22.2.1.r2268.g87b46065-11:5.22.3.r2268.g87b46065-1
                            bluez-qt5.83.0.r664.gffacc11-25.83.0.r665.g9a25983-1
                              bomber21.04.2.r516.g07153d2-121.04.3.r518.gc837d17-1
                                bovo21.04.2.r729.gd1776ed-121.04.3.r731.g856c46e-1
                              breeze5.22.2.1.r2218.gfce6f4e0-15.22.3.r2220.g7f793949-1
                         breeze-grub5.22.2.1.r11.g63136a9-15.22.3.r11.g63136a9-1
                          breeze-gtk5.22.2.1.r420.gfccd7df-15.22.3.r420.gfccd7df-1
                        breeze-icons5.83.0.r1754.g0a3ab844-25.83.0.r1755.geec9a2c4-1
                                buho 1.2.2.r29.g5cb0188-2 1.2.2.r30.gbb2429b-1
                     calendarsupport21.04.2.r558.g2215dc3-121.04.3.r566.ge222d75-1
                           calindori  21.06.r5.gd655e21-1  21.06.r6.gf760462-1
                            cervisia21.04.2.r1637.g3e29b0d-121.04.3.r1639.g3007798-1
                            discover5.22.2.1.r8215.g725ae1f2-15.22.3.r8232.g5f7751f4-1
                             dolphin21.04.2.r6627.g902e8ee07-121.04.3.r6645.g3fdd93db9-1
                     dolphin-plugins21.04.2.r586.g18cabb0-121.04.3.r591.g6f8984f-1
                              dragon21.04.2.r1003.g16c7b9f-121.04.3.r1006.gd9f5cfa-1
                             drkonqi5.22.2.1.r658.g29546781-15.22.3.r665.gcaa06a2c-1
                               elisa21.04.2.r2727.gee28f06a-121.04.3.r2736.g7fb3d070-1
                          eventviews21.04.2.r662.gb75379f-121.04.3.r669.gff0d774-1
                 extra-cmake-modules5.83.0.r3331.gf776d39-15.84.0.r3340.g9d45e55-1
                        ffmpegthumbs21.04.2.r188.g00f9186-121.04.3.r189.g76a13b3-1
                           filelight21.04.2.r976.g1702097-121.04.3.r978.gd62b437-1
                frameworkintegration5.83.0.r587.g254467b-25.83.0.r588.gef4ec10-1
                           granatier21.04.2.r921.g9c7e554-121.04.3.r923.g82225d9-1
                     grantlee-editor21.04.2.r748.g78d239e-121.04.3.r754.g9870fa0-1
                       grantleetheme21.04.2.r326.g99e0d43-121.04.3.r331.g05475f0-1
                            gwenview21.04.2.r6628.g89bfe886-121.04.3.r6644.gb9a21ed5-1
                     incidenceeditor21.04.2.r733.gc4304cf-121.04.3.r742.gb91c878-1
                            index-fm 1.2.2.r77.gd9d681e-2 1.2.2.r94.g6bbd63c-1
                           itinerary21.04.2.r1343.gfab4b91-121.04.3.r1362.gb9d1eeb-1
                                 juk21.04.2.r3105.g3b94a681-121.04.3.r3108.g0e63bb44-1
                                 k3b1:21.04.2.r6646.gb203c9e12-11:21.04.3.r6652.gfbea53425-1
               kaccounts-integration21.04.2.r1207.gb36372a-121.04.3.r1209.g3b5ef30-1
                 kaccounts-providers21.04.2.r381.gd5e0c45-121.04.3.r382.g2f7fb54-1
                         kactivities5.83.0.r1350.g0fa2366-25.83.0.r1351.g5c286e5-1
                   kactivities-stats5.83.0.r358.gc6c3655-25.83.0.r360.g802b063-1
                   kactivitymanagerd5.22.2.1.r1355.g9cabb88-15.22.3.r1355.g9cabb88-1
                             kajongg21.04.2.r4192.g94794aef-121.04.3.r4195.gf8c5ac9e-1
                              kalarm21.04.2.r6390.g76656661-121.04.3.r6402.g59f6695d-1
                           kalarmcal21.04.2.r1116.gc3d0dc8-121.04.3.r1121.g667bf5f-1
                            kalgebra21.04.2.r2034.g8ccd627-121.04.3.r2039.gd170a8d-1
                             kalzium21.04.2.r4251.gb7804b8b-121.04.3.r4253.g1481dd2b-1
                              kamera21.04.2.r653.gd09472c-121.04.3.r654.g9eadd76-1
                              kamoso21.04.2.r1425.g9a3017c-121.04.3.r1427.gfda571b-1
                            kanagram21.04.2.r1278.gd2d336b-121.04.3.r1280.g871912c-1
                             kapidox5.83.0.r530.g0e9021e-25.84.0.r540.g2fc5e0d-1
                              kapman21.04.2.r597.g4c0e4c3-121.04.3.r599.g98d5783-1
                        kapptemplate21.04.2.r951.g57b0257-121.04.3.r953.g27f61d7-1
                            karchive5.83.0.r489.g8c290d1-15.84.0.r492.g2a1acbd-1
                               kasts 21.06.r34.gd0bc5b2-1 21.06.r67.g041b1ed-1
                                kate21.04.2.r18261.g53e83185a-121.04.3.r18283.g11ed6456b-1
                             katomic21.04.2.r911.g27db726-121.04.3.r913.g943bd88-1
                               kauth5.83.0.r437.g3d69fa9-25.84.0.r439.gf48b5bf-1
                             kbackup21.04.2.r376.g79be946-121.04.3.r380.g4ccaae3-1
                           kblackbox21.04.2.r721.g77a58d5-121.04.3.r723.g6ca4526-1
                             kblocks21.04.2.r637.g4ee95b8-121.04.3.r663.g4b38480-1
                          kbookmarks5.83.0.r409.g4270cd1-25.84.0.r410.gad346c1-1
                             kbounce21.04.2.r799.gfdce48d-121.04.3.r801.gf8f667b-1
                           kbreakout21.04.2.r855.gc80c29c-121.04.3.r858.g86ab50b-1
                              kbruch21.04.2.r813.gce09ef3-121.04.3.r815.ge3701fb-1
                         kcachegrind21.04.2.r1147.g093b45f-121.04.3.r1150.g0e6745f-1
                  kcachegrind-common21.04.2.r1147.g093b45f-121.04.3.r1150.g0e6745f-1
                               kcalc21.04.2.r1507.gf4f095a-121.04.3.r1510.g22dd01f-1
                       kcalendarcore5.83.0.r1217.gcf903ae1d-15.83.0.r1219.ga2df8844b-1
                           kcalutils21.04.2.r849.g6a7b3bb6f-121.04.3.r854.g11d58ffb1-1
                         kcharselect21.04.2.r466.g1846940-121.04.3.r468.g53bc45e-1
                              kclock 21.06.r13.g5b8cf12-1 21.06.r15.g2385a20-1
                            kcmutils5.83.0.r521.g276a88e-25.83.0.r523.g2411f4c-1
                             kcodecs5.83.0.r372.gf0ff68d-25.84.0.r372.gf0ff68d-1
                       kcolorchooser21.04.2.r222.g255ab9a-121.04.3.r224.g29e79c1-1
                         kcompletion5.83.0.r445.g1c592f7-25.84.0.r446.g54e95d0-1
                             kconfig5.83.0.r841.g74a861c-25.84.0.r846.gbd53bb3-1
                      kconfigwidgets5.83.0.r591.geb4f326-25.84.0.r595.g9381bbe-1
                           kcontacts1:5.83.0.r3243.g97085a69-21:5.83.0.r3244.g2f7f8bcb-1
                         kcoreaddons5.83.0.r1238.g718ec693-15.84.0.r1241.g4cd7e789-1
                              kcrash5.83.0.r398.g6077f47-15.84.0.r399.g4921623-1
                               kcron21.04.2.r773.gd10d4db-121.04.3.r775.g91d5a01-1
                                kdav1:5.83.0.r1288.g735ff1b-21:5.83.0.r1289.g2795a0d-1
                         kdbusaddons5.83.0.r367.g80a309c-25.84.0.r370.g29dfe25-1
                       kde-cli-tools5.22.2.1.r1845.gddccf63-15.22.3.r1845.gddccf63-1
                     kde-dev-scripts21.04.2.r4137.g8f98b13-121.04.3.r4137.g8f98b13-1
                       kde-dev-utils21.04.2.r553.g358a3de-121.04.3.r556.g6d918c3-1
                      kde-gtk-config5.22.2.1.r895.g93da65a-15.22.3.r895.g93da65a-1
                      kdebugsettings21.04.2.r809.gf363133-121.04.3.r827.g370cdc2-1
                        kdeclarative5.83.0.r900.gf5a17e9-25.83.0.r901.g580a694-1
                          kdeconnect21.04.2.r3272.gea8ed5c4-121.04.3.r3278.g296de907-1
                         kdecoration5.22.2.1.r267.g7be8cbb-15.22.3.r268.g1dabf57-1
                                kded5.83.0.r407.g4eda499-15.83.0.r409.g01943ff-1
                         kdeedu-data21.04.2.r15.g8dc3dee-121.04.3.r15.g8dc3dee-1
              kdegraphics-mobipocket21.04.2.r259.g9c61298-121.04.3.r259.g9c61298-1
            kdegraphics-thumbnailers21.04.2.r233.g3f941f1-121.04.3.r233.g3f941f1-1
                     kdelibs4support5.83.0.r1023.gee8bd6c6-25.83.0.r1026.g44dee8c4-1
              kdenetwork-filesharing21.04.2.r889.g0abade9-121.04.3.r889.g0abade9-1
                       kdepim-addons21.04.2.r4191.gb6b41223-121.04.2.r4233.g72caee05-1
                      kdepim-runtime21.04.2.r15132.gdf1a495bb-121.04.3.r15145.g74ef1624e-1
                    kdeplasma-addons5.22.2.1.r8549.g0b660afd1-15.22.3.r8553.g77b88b999-1
                    kdesdk-kioslaves21.04.2.r497.g75b86a2-121.04.3.r498.g061c880-1
                 kdesdk-thumbnailers21.04.2.r83.gb498057-121.04.3.r84.gd7821b4-1
                     kdesignerplugin5.83.0.r327.g5a75ff1-25.83.0.r328.g0b12b99-1
                               kdesu5.83.0.r467.g050de94-15.83.0.r468.g3daa918-1
                           kdewebkit5.83.0.r273.g8f16e7c-25.83.0.r274.gefed877-1
                                 kdf21.04.2.r789.g18fb281-121.04.3.r790.gb2a8614-1
                             kdialog21.04.2.r1181.g8b80e3786-121.04.3.r1183.g3c9c5e3a9-1
                            kdiamond21.04.2.r663.g2e79b99-121.04.3.r665.g639f619-1
                              kdnssd5.83.0.r314.gbecf0ea-25.83.0.r315.g4ba7121-1
                           kdoctools5.83.0.r612.g70e1ca7-25.84.0.r614.gb87709c-1
                      keditbookmarks21.04.2.r2739.gfc1e52c7a-121.04.3.r2740.g956c0e3dc-1
                          kemoticons5.83.0.r375.gd716cdb-25.83.0.r376.gbeed4ec-1
                       kfilemetadata5.83.0.r797.g16c2da9-25.83.0.r798.g3847089-1
                               kfind21.04.2.r2632.g4ebc96a8f-121.04.3.r2634.gdce809f04-1
                             kfloppy21.04.2.r750.g2aad2a3-121.04.3.r752.g691d766-1
                         kfourinline21.04.2.r975.gcabd9a4-121.04.3.r977.gdc073b4-1
                             kgamma55.22.2.1.r456.g5885d2f-15.22.3.r456.g5885d2f-1
                          kgeography21.04.2.r1108.g889d027-121.04.3.r1110.gc64e87c-1
                                kget21.04.2.r3108.g85a2f746-121.04.3.r3116.gc75a0da8-1
                        kglobalaccel5.83.0.r450.ge32cc99-25.84.0.r451.g86899db-1
                         kgoldrunner21.04.2.r1228.gd0a5276-121.04.3.r1234.g79209db-1
                                kgpg21.04.2.r3122.g9c45b462-121.04.3.r3128.g374d7a3b-1
                          kguiaddons5.83.0.r376.g2a9ae43-25.84.0.r377.g9047512-1
                            khangman21.04.2.r1560.ge45af9d-121.04.3.r1562.gd6f7474-1
                         khelpcenter21.04.2.r2670.g8ad58850-121.04.3.r2673.gc8241571-1
                           kholidays1:5.83.0.r940.g94f52b4-21:5.83.0.r943.gd0c15ca-1
                            khotkeys5.22.2.1.r2074.gcaad4c1-15.22.3.r2074.gcaad4c1-1
                               khtml5.83.0.r548.g8540c72-25.83.0.r550.g7734b7f-1
                               ki18n5.83.0.r469.gd181a83-15.84.0.r470.g4ef749b-1
                         kiconthemes5.83.0.r528.g4dbe2df-25.84.0.r531.g7edcfab-1
                 kidentitymanagement21.04.2.r3785.ge6290153-121.04.3.r3792.g0b2875ba-1
                           kidletime5.83.0.r305.g5e3bada-25.83.0.r306.g1e5792e-1
                                 kig21.04.2.r3137.g532f432d-121.04.3.r3140.gdcb670bd-1
                                kigo21.04.2.r515.g8701c1b-121.04.3.r518.g9a11075-1
                            killbots21.04.2.r725.g11e9d29-121.04.3.r732.g7da9165-1
                       kimageformats5.83.0.r343.g1b2bf6e-25.83.0.r344.g3266a9c-1
                     kimagemapeditor21.04.2.r465.ga69f3d1-121.04.3.r469.g9c81281-1
                               kimap21.04.2.r1094.g0fe0e54-121.04.3.r1100.ga376bc4-1
                         kinfocenter5.22.2.1.r1852.g5b06520-15.22.3.r1861.g07fdf4a-1
                               kinit5.83.0.r402.g9d3629e-25.84.0.r403.g88e23a2-1
                                 kio5.83.0.r4822.gfb9bbb6f-15.84.0.r4833.g36f1814b-1
                          kio-extras21.04.2.r7063.ga5e17084-121.04.3.r7088.gcec49d39-1
                          kio-gdrive21.04.2.r556.g9824d74-121.04.3.r560.g44f483d-1
                        kipi-plugins21.04.2.r12061.g955fc31c6-121.04.3.r12061.g955fc31c6-1
                    kirigami-gallery21.04.2.r207.g38d56e0-121.04.3.r211.g09e7613-1
                           kirigami25.83.0.r2820.ga7689f8d-25.84.0.r2828.ga1b3913e-1
                              kiriki21.04.2.r414.g3eb1ea1-121.04.3.r417.gec9e2ef-1
                         kitemmodels5.83.0.r544.g48bf306-25.83.0.r545.g755cdd1-1
                          kitemviews5.83.0.r329.gc590771-25.84.0.r330.g2716299-1
                               kiten21.04.2.r1140.g10c4ca4-121.04.3.r1142.g4553fc6-1
                          kitinerary21.04.2.r1813.gc0f6757-121.04.3.r1820.g5058071-1
                         kjobwidgets5.83.0.r367.g2206ec1-25.84.0.r368.g9c6142f-1
                                 kjs5.83.0.r328.g0d0145a-25.83.0.r329.gca14caf-1
                            kjsembed5.83.0.r297.gf32de40-25.83.0.r298.g9de8ed7-1
                        kjumpingcube21.04.2.r777.g2a1f947-121.04.3.r781.g2238a93-1
                               kldap21.04.2.r864.gda9332a-121.04.3.r868.g174e41b-1
                           kleopatra21.04.2.r5907.g08d42db6-121.04.3.r5913.gbb92dfd2-1
                            klettres21.04.2.r910.gffbe82f-121.04.3.r912.g6f0aff5-1
                            klickety21.04.2.r621.g8b95538-121.04.3.r630.gf8576a2-1
                              klines21.04.2.r735.gc409f0c-121.04.3.r743.g7aa89f1-1
                                kmag21.04.2.r687.g8a3d886-121.04.3.r689.gdb43b34-1
                           kmahjongg21.04.2.r1464.g80e61ed-121.04.3.r1466.g1b677ae-1
                kmail-account-wizard21.04.2.r784.g4ff0660-121.04.3.r790.g8a1654a-1
                      kmailtransport21.04.2.r1613.g5f549b4-121.04.3.r1619.gae8911b-1
                               kmbox21.04.2.r522.g5d18026-121.04.3.r528.g3176ee3-1
                        kmediaplayer5.83.0.r289.g7c9045b-25.83.0.r290.gd16226b-1
                           kmenuedit5.22.2.1.r968.g2742003-15.22.3.r968.g2742003-1
                               kmime21.04.2.r1435.gd813506-121.04.3.r1440.g43a6ce0-1
                              kmines21.04.2.r1709.g4ca019d-121.04.3.r1713.gd98ba9e-1
                                kmix21.04.2.r2369.g28a3450a-121.04.3.r2371.gdd7e4de8-1
                          kmousetool21.04.2.r387.g3e256a8-121.04.3.r387.g3e256a8-1
                              kmouth21.04.2.r692.g434a8a6-121.04.3.r692.g434a8a6-1
                              kmplot21.04.2.r1459.g6cdacb6-121.04.3.r1459.g6cdacb6-1
                        knavalbattle21.04.2.r1379.g70ebfeb-121.04.3.r1381.gbe44ade-1
                            knetwalk21.04.2.r648.ge3b8b85-121.04.3.r650.g319553b-1
                           knewstuff5.83.0.r1179.gc1301e0f-15.83.0.r1182.g6788cf4f-1
                             knights21.04.2.r1046.g9c41563-121.04.3.r1048.g593573b-1
                              knotes21.04.2.r3466.g330d3c98-121.04.3.r3473.g1891433d-1
                      knotifications5.83.0.r664.g8afb010-25.84.0.r666.g4e638d1-1
                       knotifyconfig5.83.0.r345.g38fd196-25.83.0.r346.g1725410-1
                                koko 21.06.r14.gaee324e-1 21.06.r17.gdcd1ea2-1
                                kolf21.04.2.r1416.g255c4fc-121.04.3.r1430.gfb632a5-1
                           kollision21.04.2.r483.gc56666d-121.04.3.r485.gbe33dc3-1
                         kolourpaint21.04.2.r2346.g32ab2886-121.04.3.r2348.g11e1c189-1
                             kompare21.04.2.r1100.gc15db89-121.04.3.r1102.gc5cfcde-1
                           konqueror21.04.2.r14912.g5ef5bf6a2-121.04.3.r14913.g30aea7bcb-1
                            konquest21.04.2.r888.g8b6d0b6-121.04.3.r890.g38d88bd-1
                             konsole21.04.2.r7867.gd468bbab-121.04.3.r7882.g26018e3a-1
                             kontact21.04.2.r5328.g56050423-121.04.3.r5341.g222bece2-1
                    kontactinterface21.04.2.r615.gd712c47-121.04.3.r620.g9ea7cf2-1
                            kontrast21.04.2.r167.gaf1bb0b-121.04.3.r169.gb64bb54-1
                        konversation21.04.2.r8982.g4be5cb00-121.04.3.r8986.gf06db9ae-1
                       kopeninghours21.04.2.r266.g95e49b8-121.04.3.r267.g81cc4e5-1
                          korganizer21.04.2.r11395.ged70d5136-121.04.3.r11403.g281f79894-1
                       kosmindoormap21.04.2.r615.g8d46d30-121.04.3.r619.geb851a4-1
                            kpackage5.83.0.r671.gf617caf-25.84.0.r675.g9acb251-1
                              kparts5.83.0.r511.g0a39505-15.83.0.r512.g4dbc8b4-1
                                kpat21.04.2.r2555.g4e44cd3-121.04.3.r2559.g1b5eda1-1
                             kpeople5.83.0.r1333.gb793989-25.83.0.r1335.gb6b58af-1
                        kpimtextedit21.04.2.r1387.gc173318-121.04.3.r1392.gc08755a-1
                             kpkpass21.04.2.r225.g3e64e9b-121.04.3.r229.g16211f8-1
                           kplotting5.83.0.r284.g4f0e792-25.83.0.r285.g48b6d33-1
                             kpmcore21.04.2.r1192.gf018824-121.04.3.r1195.gc47ee6c-1
                                kpty5.83.0.r328.gbbfabe3-25.83.0.r330.g03a517a-1
                    kpublictransport21.04.2.r1689.g558a5b5a-121.04.2.r1692.g7d976ae5-1
                      kqtquickcharts21.04.2.r74.g264af68-121.04.3.r74.g264af68-1
                        kquickcharts5.83.0.r463.g6ec02ab-25.83.0.r464.gec46053-1
                                krdc21.04.2.r1525.gd59e362-121.04.3.r1529.gdb18bb3-1
                            kreversi21.04.2.r1214.g028f16e-121.04.3.r1216.gc9646c1-1
                                krfb21.04.2.r1399.g0316c37-121.04.3.r1407.g75bff9d-1
                               kross5.83.0.r327.gce48a10-25.83.0.r328.g7d48e4f-1
                  kross-interpreters21.04.2.r722.g8d54326-121.04.3.r722.g8d54326-1
                              kruler21.04.2.r689.g5d12ffa-121.04.3.r691.gbdd7e07-1
                             krunner5.83.0.r635.g8e246cc-25.83.0.r642.gbcd11b6-1
                             kscreen5.22.2.1.r1336.ge6feadd-15.22.3.r1337.g413adfe-1
                       kscreenlocker5.22.2.1.r856.g372a234-15.22.3.r857.gad1fa64-1
                            kservice5.83.0.r921.gfc55736-25.84.0.r922.g2900204-1
                             kshisen21.04.2.r1193.gaaf1e14-121.04.3.r1195.g782afbf-1
                               ksirk21.04.2.r956.g4f0e5e8-121.04.3.r958.g762ccee-1
                               ksmtp21.04.2.r351.g169f0fe-121.04.3.r357.g6357856-1
                          ksnakeduel21.04.2.r794.g6dad1da-121.04.3.r796.gb4178a5-1
                          kspaceduel21.04.2.r621.gf4072ce-121.04.3.r623.g026456a-1
                            ksquares21.04.2.r509.g970e068-121.04.3.r511.gd306032-1
                         ksshaskpass5.22.2.1.r196.gdaa2679-15.22.3.r196.gdaa2679-1
                             ksudoku21.04.2.r1044.g19e3de6-121.04.3.r1046.g245abab-1
                           ksysguard5.22.2.1.r3507.g9bc6de87-15.22.3.r3507.g9bc6de87-1
                          ksystemlog21.04.2.r640.gae84fb5-121.04.3.r648.ga5b2adc-1
                        ksystemstats5.22.2.1.r174.g0639a7f-15.22.3.r174.g0639a7f-1
                            kteatime21.04.2.r717.g94dd38e-121.04.3.r719.g28209c4-1
                         ktexteditor5.83.0.r2897.g0194c22d-15.83.0.r2903.g6a7e6286-1
                        ktextwidgets5.83.0.r401.g1bec4bc-25.84.0.r402.g3399228-1
                              ktimer21.04.2.r464.gd79dbc2-121.04.3.r466.g3495155-1
                               ktnef21.04.2.r649.g0325699-121.04.3.r654.g3cb0be9-1
                            ktorrent21.04.2.r2753.g81378576-121.04.3.r2755.gd3a3239c-1
                              ktouch21.04.2.r2134.g59d2fbf-121.04.3.r2136.g3f40f66-1
                               ktrip 21.06.r22.g1c9b25a-1 21.06.r23.g57bd918-1
                          ktuberling21.04.2.r1001.ga0d2404-121.04.3.r1003.g75890ff-1
                             kturtle21.04.2.r1111.gcd6a6f3-121.04.3.r1113.g94c8f6d-1
                             kubrick21.04.2.r363.g6b31f81-121.04.3.r365.gc949aa8-1
                     kunitconversion5.83.0.r367.gbe47ed6-25.83.0.r368.gfafa510-1
                             kwallet5.83.0.r1072.g1725111-25.84.0.r1075.gf5fc49b-1
                         kwallet-pam5.22.2.1.r248.ge91fcbe-15.22.3.r248.ge91fcbe-1
                      kwalletmanager21.04.2.r1197.g0cf5f7a-121.04.3.r1199.gbdc66ef-1
                               kwave21.04.2.r3735.gbe0fbd8d-121.04.3.r3737.gc6213fa5-1
                            kwayland5.83.0.r1093.g2634a19-25.83.0.r1095.g2adaa15-1
                kwayland-integration5.22.2.1.r179.g5901512-15.22.3.r179.g5901512-1
                     kwayland-server5.22.2.1.r1341.g63bd0e3-15.22.3.r1343.g893e4a1-1
                      kwidgetsaddons5.83.0.r830.g980f2242-25.84.0.r833.gbac6de40-1
                                kwin5.22.2.1.r19600.g8386a8bb6-15.22.3.r19639.g23129c09c-1
                       kwindowsystem5.83.0.r596.g5413356-25.84.0.r597.gcb33999-1
                           kwordquiz21.04.2.r1137.gae54e22-121.04.3.r1139.g62eb3a3-1
                              kwrite21.04.2.r18261.g53e83185a-121.04.3.r18283.g11ed6456b-1
                             kwrited5.22.2.1.r479.g8d34f29-15.22.3.r479.g8d34f29-1
                             kxmlgui5.83.0.r784.g8df0baa5-25.84.0.r785.g4c6acb75-1
                       kxmlrpcclient5.83.0.r450.g179493558-25.83.0.r451.g330436966-1
                          libakonadi21.04.2.r12512.ge9f90a3b0-121.04.3.r12519.g0bc009687-1
                         libgravatar21.04.2.r353.g8714f65-121.04.3.r358.g027f657-1
                            libkcddb21.04.2.r736.g24d5755-121.04.3.r736.g24d5755-1
                     libkcompactdisc21.04.2.r386.g4f9a6d2-121.04.3.r386.g4f9a6d2-1
                           libkdcraw21.04.2.r1148.g4af2f68-121.04.3.r1148.g4af2f68-1
                         libkdegames21.04.2.r2179.g27e8411d-121.04.3.r2181.g4e7bbf7f-1
                           libkdepim21.04.2.r833.g148711e-121.04.3.r839.gc514137-1
                  libkeduvocdocument21.04.2.r1791.g4966f86-121.04.3.r1791.g4966f86-1
                           libkexiv221.04.2.r815.gb0e00f4-121.04.3.r815.gb0e00f4-1
                            libkgapi21.04.2.r1280.g4d67b6d-121.04.3.r1285.g9c05e62-1
                             libkipi21.04.2.r1250.geea9c7b-121.04.3.r1250.geea9c7b-1
                             libkleo21.04.2.r907.g33b28a9-121.04.3.r913.g1ff8583-1
                        libkmahjongg21.04.2.r452.g51782b7-121.04.3.r453.g0d54bba-1
                     libkomparediff221.04.2.r336.g36da81f-121.04.3.r336.g36da81f-1
                            libksane21.04.2.r539.g9a3ab2a-121.04.3.r549.gcd38e98-1
                          libkscreen5.22.2.1.r1583.gd916c2a-15.22.3.r1585.g19fb52b-1
                           libksieve21.04.2.r1534.g7716481f-121.04.3.r1545.g3300d331-1
                        libksysguard5.22.2.1.r2245.g402b521-15.22.3.r2252.g375ee5b-1
                         libktorrent21.04.2.r519.gdb6f72a-121.04.3.r520.g614e231-1
                            lokalize21.04.2.r1765.gc4d0843-121.04.3.r1767.g3541bb0-1
                               lskat21.04.2.r803.g199b556-121.04.3.r805.gb70ac1d-1
                          mailcommon21.04.2.r1041.g3e6fa73-121.04.3.r1053.g53624c3-1
                        mailimporter21.04.2.r456.g62c206b-121.04.3.r461.g3677c0d-1
                              marble21.04.2.r13315.g446a2e579-121.04.3.r13316.g0fe8ffc99-1
                       marble-common21.04.2.r13315.g446a2e579-121.04.3.r13316.g0fe8ffc99-1
                           marble-qt21.04.2.r13315.g446a2e579-121.04.3.r13316.g0fe8ffc99-1
                        markdownpart21.04.2.r73.g9189ff3-121.04.3.r76.gcf104d8-1
                           maui-nota 1.2.2.r44.g82927e9-2 1.2.2.r49.gedc609a-1
                            maui-pix 1.2.2.r52.g153b4f4-1 1.2.2.r56.gee6e755-1
                    mauikit-accounts         r6.8f01110-2         r8.3324a33-1
                mauikit-filebrowsing 1.2.2.r59.gbb9ca4c-2 1.2.2.r64.ga123902-1
                  mauikit-texteditor  1.2.2.r7.gaa0d310-2  1.2.2.r8.g8a7b033-1
                       mbox-importer21.04.2.r497.g56b4d69-121.04.3.r502.gfe6e5f9-1
                          messagelib21.04.2.r6054.g8274c804-121.04.3.r6066.g38461aa2-1
                               milou5.22.2.1.r745.g65c72f4-15.22.3.r745.g65c72f4-1
                              minuet21.04.2.r575.g2ec077c-121.04.3.r577.ga4303ed-1
                     modemmanager-qt5.83.0.r510.gc2d3596-25.83.0.r513.gaf2046f-1
                             neochat    r1780.g53741635-1    r1783.g35aac4e3-1
                   networkmanager-qt5.83.0.r1107.g677b986-25.83.0.r1109.gc4f8663-1
                              okular21.04.2.r9385.g7c9322ad7-121.04.3.r9393.g5447aa102-1
                              oxygen5.22.2.1.r4422.g5c8c3271-15.22.3.r4422.g5c8c3271-1
                            palapeli21.04.2.r1223.ga39f151-121.04.3.r1225.gfd17215-1
                              parley21.04.2.r4412.g77e052c7-121.04.3.r4414.gdc7ae8d4-1
                    partitionmanager21.04.2.r1526.g9212d74-121.04.3.r1528.gc0565bd-1
                               picmi21.04.2.r526.ge88c260-121.04.3.r526.ge88c260-1
                   pim-data-exporter21.04.2.r2414.g54219a58-121.04.3.r2421.gb2205fd4-1
                    pim-sieve-editor21.04.2.r1483.g2acd06b-121.04.3.r1493.ge0cae80-1
                           pimcommon21.04.2.r1056.ga49b86c-121.04.3.r1063.g88519b7-1
          plasma-browser-integration5.22.2.1.r1266.gdc031190-15.22.3.r1266.gdc031190-1
                      plasma-desktop5.22.2.1.r8533.g28723b62f-15.22.3.r8544.g424e9b2e4-1
                       plasma-dialer  21.06.r4.gfa1d0ee-2  21.06.r5.g6566de5-1
                        plasma-disks5.22.2.1.r218.ga61c07c-15.22.3.r220.gc883001-1
                     plasma-firewall5.22.2.1.r496.gbdd33c0-15.22.3.r497.g8e86ae7-1
                    plasma-framework5.83.0.r15902.g2ad8174b4-15.83.0.r15909.g057b74476-1
                  plasma-integration5.22.2.1.r519.gf7c25d9-15.22.3.r519.gf7c25d9-1
                           plasma-nm5.22.2.1.r3061.gf6e45d40-15.22.3.r3062.ge3474d8f-1
                           plasma-pa5.22.2.1.r949.g5a0d555-15.22.3.r950.g6ff7099-1
             plasma-phone-components5.22.2.1.r1423.g7c8fc779-15.22.3.r1423.g7c8fc779-1
                          plasma-sdk5.22.2.1.r2271.gfdb53f2b-15.22.3.r2272.g32b423a6-1
                plasma-systemmonitor5.22.2.1.r459.g03165f5-15.22.3.r465.g2aa482c-1
                  plasma-thunderbolt5.22.2.1.r133.g176fb93-15.22.3.r134.gff4b4f9-1
                        plasma-vault5.22.2.1.r336.g2b49118-15.22.3.r336.g2b49118-1
              plasma-wayland-session5.22.2.1.r10422.gfce72eea0-15.22.3.r10433.g70a69b00c-1
                    plasma-workspace5.22.2.1.r10422.gfce72eea0-15.22.3.r10433.g70a69b00c-1
         plasma-workspace-wallpapers5.22.2.1.r278.g90dc1bd-15.22.3.r279.g5bf6b8d-1
                    polkit-kde-agent5.22.2.1.r498.g12157d1-15.22.3.r498.g12157d1-1
                          powerdevil5.22.2.1.r2442.g93e441d9-15.22.3.r2442.g93e441d9-1
                               poxml21.04.2.r277.ge2d4dfb-121.04.3.r277.ge2d4dfb-1
                       print-manager21.04.2.r1028.ga67b660-121.04.3.r1033.g927adec-1
                              prison5.83.0.r318.gdad8665-25.83.0.r320.geb20509-1
                             purpose5.83.0.r861.g7ae34b9-25.83.0.r862.g2ca6b6b-1
                         qcachegrind21.04.2.r1147.g093b45f-121.04.3.r1150.g0e6745f-1
                          qmlkonsole  21.06.r3.g8ec415c-1  21.06.r4.g13dd175-1
                  qqc2-desktop-style5.83.0.r493.ge224a1d-15.83.0.r498.gf5307d1-1
         qt5-es2-xcb-private-headers    5.15.2+kde+r203-1                    -
                                rocs21.04.2.r3016.g80c7c4a9-121.04.2.r3018.g528540e7-1
                                sddm0.19.0.r39.ge64a87d-10.19.0.r49.gbb54497-1
                            sddm-kcm5.22.2.1.r587.g4fd430d-15.22.3.r588.gc51c2a1-1
            signon-kwallet-extension21.04.2.r64.g47e187d-121.04.3.r65.g82912be-1
                               solid5.83.0.r682.g8f12a27-25.84.0.r687.gcde7831-1
                              sonnet5.83.0.r619.g248722a-25.84.0.r620.g430697e-1
                            spacebar 21.06.r18.g126ded9-1 21.06.r22.gecc0155-1
                           spectacle21.04.2.r1114.ge5f0001-121.04.3.r1131.g2f344ce-1
                                step21.04.2.r1151.g311e188-121.04.3.r1153.g28928cf-1
                             svgpart21.04.2.r168.gc4138f0-121.04.3.r173.g5e2839c-1
                             sweeper21.04.2.r521.g6399bd3-121.04.3.r526.g2d5be70-1
                         syndication5.83.0.r831.gfaf12a7-25.83.0.r832.g468e4ca-1
                 syntax-highlighting5.83.0.r1614.ga83a61be-15.83.0.r1623.gd5c4d1fe-1
                      systemsettings5.22.2.1.r2447.gda1ff253-15.22.3.r2453.g07fcc030-1
          telepathy-kde-accounts-kcm21.04.2.r1192.g5a27a75-121.04.3.r1195.gd0ffbec-1
              telepathy-kde-approver21.04.2.r294.g6594053-121.04.3.r295.g4f4fc32-1
          telepathy-kde-auth-handler21.04.2.r276.g48e529c-121.04.3.r277.g1db14c4-1
               telepathy-kde-call-ui21.04.2.r445.g8815182-121.04.3.r445.g8815182-1
      telepathy-kde-common-internals21.04.2.r1993.g48d6a2e-121.04.3.r1994.g4d6f30e-1
          telepathy-kde-contact-list21.04.2.r1084.gd88224a-121.04.3.r1085.g6ede63e-1
        telepathy-kde-contact-runner21.04.2.r252.g6d4f602-121.04.3.r253.g9fa10bb-1
       telepathy-kde-desktop-applets21.04.2.r993.g24d97f9-121.04.3.r994.g93ae844-1
  telepathy-kde-filetransfer-handler21.04.2.r219.gd345782-121.04.3.r220.g3eb1cbb-1
    telepathy-kde-integration-module21.04.2.r390.g08eac55-121.04.3.r391.g52b0f46-1
             telepathy-kde-send-file21.04.2.r227.g53297c0-121.04.3.r228.g376d937-1
               telepathy-kde-text-ui21.04.2.r2019.g2cae1c7-121.04.3.r2020.gf0e1be3-1
                        threadweaver5.83.0.r501.g156fdb6-25.83.0.r502.g79794c5-1
                             tokodon 21.06.r11.g99c47b5-1 21.06.r13.g1768eb9-1
                            umbrello21.04.2.r8260.g929067310-121.04.3.r8261.g8ac7e25df-1
                               vvave 1.2.2.r40.gd794531-2 1.2.2.r48.g709b880-1
                            wrapland5.22.0.r1474.g64c4443-15.22.0.r1497.ge908f22-1
              xdg-desktop-portal-kde5.22.2.1.r371.gdbfd020-15.22.3.r374.g96ead88-1
                             yakuake21.04.2.r722.g0eb3a30-121.04.3.r723.gf920d67-1
                    zeroconf-ioslave21.04.2.r351.g2df5266-121.04.3.r353.g4db270b-1
                    plasma-mobile-nm                    -5.21.4.r3061.gf6e45d40-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
systemd-hook unsuccesful after pacman 6 update
After the pacman 6 update, updates will create this message in the post-transation hooks part:
Running the command manually works and there has been no issues reported as the result of this. This will either get fixed at some point in Pacman or SystemD.
Keyring issues
If you have some gpg keyring issues, you can run sudo systemctl start pacman-init.service which will regenerate your keyring. Will take a few minutes to complete.
Old Issues
Plasma Mobile no longer boots
The current update to qt5-es2-base results in Plasma Mobile no longer booting, showing a screen that says to run a loginctl command to login.
Fixed by updating to qt5-es2-base-5.15.2+kde+r199-3.1 and qt5-es2-declarative-5.15.2+kde+r28-3.1.
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
Save the file and reboot.
@Strit quick question: does https://repo.manjaro.org reflect the status ARM packages? or is that currently only for x86_64?
Should be both.
Everything went well, except Moson serving xorg-server-common at less than 1kb for >10 secs.
:laughing:
Thanks for the update.
:+1: :slight_smile:
+1 for Firefox 90 on Plasma + fbturbo
XFCE on rpi4 4GB crashes at some point. Desktop freezes. That can be triggered by moving the mouse into the traybar over the network icon (WTF?) or by running firefox. Will test if it dies after some time or if interaction is needed.
Edit:
Ok, pinging google servers does not lead to a crash. Running journalctl -f is also ok. Moving the mouse to the traybar icons crashes the system. Running glxgears (no mesa-git) crashes after some rounds.
Stacktrace:
reading of user environment enabled
Jul 14 08:56:00 armed kernel: Unable to handle kernel paging
request at virtual address dead000000000108
Jul 14 08:56:00 armed kernel: Mem abort info:
Jul 14 08:56:00 armed kernel: ESR = 0x96000044
Jul 14 08:56:00 armed kernel: EC = 0x25: DABT (current EL)
, IL = 32 bits
Jul 14 08:56:00 armed kernel: SET = 0, FnV = 0
Jul 14 08:56:00 armed kernel: EA = 0, S1PTW = 0
Jul 14 08:56:00 armed kernel: Data abort info:
Jul 14 08:56:00 armed kernel: ISV = 0, ISS = 0x00000044
Jul 14 08:56:00 armed kernel: CM = 0, WnR = 1
Jul 14 08:56:00 armed kernel: [dead000000000108] address bet
ween user and kernel address ranges
Jul 14 08:56:00 armed kernel: Internal error: Oops: 96000044
[#1] PREEMPT SMP
Jul 14 08:56:01 armed kernel: Modules linked in: rfcomm cmac
algif_hash algif_skcipher af_alg bnep hci_uart btbcm blueto
oth ecdh_generic ecc zram zsmalloc snd_soc_hdmi_codec evdev
brcmfmac brcmutil sha256_generic sha256_arm64 bcm2835_isp(C)
cfg80211 bcm2835_codec(C) raspberrypi_hwmon bcm2835_v4l2(C)
rfkill v4l2_mem2mem bcm2835_mmal_vchiq(C) videobuf2_dma_con
tig videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videob
uf2_common vc_sm_cma(C) videodev i2c_brcmstb mc snd_bcm2835(
C) crct10dif_ce v3d gpu_sched rpivid_mem nvmem_rmem uio_pdrv
_genirq uio sch_fq_codel crypto_user fuse ip_tables x_tables
ipv6 vc4 snd_soc_core snd_compress snd_pcm_dmaengine snd_pc
m snd_timer snd drm_kms_helper syscopyarea sysfillrect sysim
gblt fb_sys_fops drm drm_panel_orientation_quirks backlight
cec
Jul 14 08:56:01 armed kernel: CPU: 1 PID: 7 Comm: kworker/u8
:0 Tainted: G C 5.10.48-1-MANJARO-ARM #1
Jul 14 08:56:01 armed kernel: Hardware name: Raspberry Pi 4
Model B Rev 1.1 (DT)
Jul 14 08:56:01 armed kernel: Workqueue: events_unbound comm
it_work [drm_kms_helper]
Jul 14 08:56:01 armed kernel: pstate: 60000005 (nZCv daif -P
AN -UAO -TCO BTYPE=–)
Jul 14 08:56:01 armed kernel: pc : clk_request_done+0x34/0xe
0
Jul 14 08:56:01 armed kernel: lr : clk_request_done+0x30/0xe
0
Jul 14 08:56:01 armed kernel: sp : ffff80001171bcd0
Jul 14 08:56:01 armed kernel: x29: ffff80001171bcd0 x28: 000
0000000000000
Jul 14 08:56:01 armed kernel: x27: ffff000040156148 x26: 000
0000000000038
Jul 14 08:56:01 armed kernel: x25: ffff00005ac0a200 x24: fff
f00004142a080
Jul 14 08:56:01 armed kernel: x23: ffff00004c881c00 x22: fff
f00004c881880
Jul 14 08:56:01 armed kernel: x21: ffff000044c2d000 x20: fff
f000043450e00
Jul 14 08:56:01 armed kernel: x19: ffff00005ac0a480 x18: 000
0000000000000
Jul 14 08:56:01 armed kernel: x17: 0000000000000002 x16: 000
0000000000001
Jul 14 08:56:01 armed kernel: x15: 0000021c2bf9a610 x14: 000
8947b3fe24e08
Jul 14 08:56:01 armed kernel: x13: 0000000000000222 x12: 000
0000000000392
Jul 14 08:56:01 armed kernel: x11: 0000000000000222 x10: 000
00000000019e0
Jul 14 08:56:01 armed kernel: x9 : ffff8000107229dc x8 : fff
f00005ac0a280
Jul 14 08:56:01 armed kernel: x7 : ffff00004198a648 x6 : fff
f800011309000
Jul 14 08:56:01 armed kernel: x5 : 0000000000000000 x4 : fff
f0000401d8000
Jul 14 08:56:01 armed kernel: x3 : ffff8000114a6ae8 x2 : dea
d000000000100
Jul 14 08:56:01 armed kernel: x1 : dead000000000122 x0 : 000
0000000000001
Jul 14 08:56:01 armed kernel: Call trace:
Jul 14 08:56:01 armed kernel: clk_request_done+0x34/0xe0
Jul 14 08:56:01 armed kernel: vc4_atomic_commit_tail+0x584/
0x6f4 [vc4]
Jul 14 08:56:01 armed kernel: commit_tail+0xac/0x190 [drm_k
ms_helper]
Jul 14 08:56:01 armed kernel: commit_work+0x20/0x30 [drm_km
s_helper]
Jul 14 08:56:01 armed kernel: process_one_work+0x1dc/0x4bc
Jul 14 08:56:01 armed kernel: worker_thread+0x148/0x47c
Jul 14 08:56:01 armed kernel: kthread+0x14c/0x160
Jul 14 08:56:01 armed kernel: ret_from_fork+0x10/0x38
Jul 14 08:56:01 armed kernel: Code: f9400800 f9400014 97ffdf
b1 a9400662 (f9000441)
Jul 14 08:56:01 armed kernel: —[ end trace 5e03b9fe140cb24
5 ]—
In config.txt I have:
dtoverlay=vc4-kms-v3d-pi4 (Is it good? I don’t know why I have that here)
For overclocking I have
arm_freq=2000
over_voltage=6
No issues in the past with that.
And I have
enable_gic=1
With latest kernel 5.13.0 the external display is no longer working on my Pinebook Pro, so I reverted back to 5.12.9, which solved the issue.
Hm, how can I move back to an older kernel? I would test that on my rpi4 to check if the issue is introduced with the new kernel.
The older kernels should be in /var/cache/pacman/pkg/ in you have not cleared the cache.
I just upgraded on the testing branch here and tested the latest linux-rpi4 and linux-rpi4-mainline kernels and I am not seeing the issues you mentioned above on my xfce install.
All fine on the PinebookPro.
One small thing: uboot is not quiet anymore: shows some output, then some flickering of the screen before the screen turns black for a while.
Interesting. It works when I use:
dtoverlay=vc4-fkms-v3d
instead of:
Where is the difference? What is “fakekms”? Does it refer to “Kernel Mode setting”?
fkms developed by RPi uses firmware provided by RPi to control the video. kms bypasses the firmware provided by RPi and uses firmware provided by the kernel and mesa to control the video.
Ah I see. FKMS acts as a shim layer and calls the old dispmanX stuff. KMS calls directly the HW functions (without using rpi closed firmware stuff).
