I did it.
I finally managed installing manjaro-xfce-0.8.1-i686.iso on Virtuabox.
On live CD
I hv increased ram to 650mb.
in order to reclaim more ram:
Stopped Conky
Stopped Screen saver process (what the hell is it for on live CD?)
Stopped networking.
(May have stopped power manager too)
It took 40 mins to reach Grub stage.
Again Manjaro failed to install GRUB.
Before installing it gave an error message as below
- Grub2 will be installed with followed settings: -
- -> Boot partition: /dev/sda1 -
- -> Target partition (MBR): /dev/sda -
- Is this correct? If not answer with "No" to change your -
- target partition, else continue with "Yes".
ls: cannot access /dev/md*: No such file or directory
- Installing GRUB2... -
=================================================it is stuck there.
I tried to reboot. I could only see word GRUB on screen .
I followed instuctions on page
http://wiki.manjaro.org/index.php/Restore_the_GRUB_Bootloaderit worked and installed GRUB manually.
my free command showed below
$ free
total used free shared buffers cached
Mem: 641228 339988 301240 0 1024 177180
-/+ buffers/cache: 161784 479444
Swap: 530140 0 530140
=====================================================XFCE was capaple of running in 512 mb of ram.
I hv stopped unnecessary services for like
screensaver
Power manager
Conky.
Mixer.
My final memory footprint is
Mem: 511840 265852 245988 0 1024 130724
-/+ buffers/cache: 134104 377736
=====================================in the bottom line:
Manjaro is great.
Installer should be improved
1) stop unnecessary services before running
Like Conky, Screensaver, or maybe powermanager, mixer.
2) Find the bug with bootloader writing.
Manjaro intelligently adjusts itself to screen resolution. (other distros unable to do that)
But fails to adjust itself to user RAM capacity.
I hope these issues will be considered by developers.
Thanking you for this great work.
Cheers
